Old 01-29-2012, 01:42 PM   #1
KEVBD
Drives: Toyota Yaris 1000cc
Question Location of Spark Plugs
Hi, I am a new member. My wife has a 2005 (1000 cc) Yaris, and as I have just retired I want to do all of the basic maintenance on the car. My first job is to locate and check the spark plugs. I had the bonnet up today, and had a look around. From just looking, I would think that the plugs are located beneath the air filter housing, and I would have to remove it to get at at least 2 of the plugs. Am I right? It is just that I read elsewhere on this forum that they are 'easy to get at as they are located beneath the decorative cover, and you simply remove the cover and there they are'.
Confused!
Mant thanks for any help
Regards
Kev
KEVBD is offline   Reply With Quote
Old 01-29-2012, 02:33 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
The spark plugs are on top of the engine block under the plastic cover with vvti on it.
Old 01-30-2012, 02:02 PM   #3
KEVBD
Many thanks Betrivent
Regards
Kev
Old 01-30-2012, 03:11 PM   #4
And then they're below the coil packs....you'll need a spark plug socket with an extension...
Old 01-30-2012, 06:13 PM   #5
RedRide
RedRide's Avatar
Also, use a spark plug socket with a rubber insert to hold on to the plug as they are down in a "hole".
Old 02-01-2012, 01:55 PM   #6
KEVBD
Thanks all for the help and advice. I removed the cover with vvti on it just to take a look see. On my wife's 2005 model this is the air filter housing, and underneath there are 4 terminals that each have what looks like a small nut holding them in place. I assume that if i undo these nuts, I will see the spark plugs yes?
Many thanks
Kev
Old 02-01-2012, 03:30 PM   #7
undo those....yes. those are the coil packs.
under teh coil packs (which are about 3" long) are the spark plugs...
Old 02-03-2012, 11:05 AM   #8
KEVBD
Many thanks
Kev
Spark Plugs walt101786 DIY / Maintenance / Service 2 12-12-2011 01:00 PM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
