Old 10-10-2014, 03:44 AM   #1
jcboy
Drives: Sedan 07
Manual mirror disassembly question
I noticed how the manual mirrors utilize coaxial metal cables for adjustment, rather than direct leverage of old. I also notice how these cables make the mirror assembly almost impossible to completely take apart (and reassemble).
My question is how take a non power mirror assembly apart without breaking or cutting anything, if at all possible?
Thanks.
Old 10-10-2014, 07:44 AM   #2
What exactly are you trying to take apart? If it is to get the mirror glass off, you tilt the mirror up, get your fingers under the bottom, and pull straight out. Once you unclip the bottom, you lift up on the glass to release the top hooks. At that point you have full access to the internals and to the clips that hold the covers on.
Old 10-10-2014, 10:03 AM   #3
jcboy
Drives: Sedan 07
I was able to do that already, thanks to your guide in another post.
I'm trying to take apart the base and the mechanisms (practically take everything apart).
i've removed all screws and T25 Torx (base), but the only thing hindering me from completing the process are the wires for the adjustment. i can't seem to find a way to remove them (without cutting them) and be able to put them back.
Old 10-10-2014, 10:15 AM   #4
Sometimes those kind of mechanisms are built where they are not designed to be taken back apart.
Old 10-10-2014, 04:04 PM   #5
ucsmfu
Drives: yaris le
same technique to remove the side mirror glass from the 2012 Yaris as well ?
Thanks Scott
ucsmfu is offline   Reply With Quote
Old 10-10-2014, 10:47 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
The base have one of those washers to attach the folding mechanism that once pushed in, they cannot be removed without cutting. Not sure why you'd want to take it completely apart.
Old 10-10-2014, 12:21 PM   #7
jcboy
Drives: Sedan 07
Oh i see. Thanks. I guess i have no choice then.
I want to take it apart because i want to be able to transfer my current power mirror to it, as the one i bought has been painted clear so its a bit satin-ny in terms of shine. Just the OC in me wanting all the black parts to match 100%.
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 10:02 PM
manual vs. automatic osmoq Fuel Economy Forum 82 01-26-2017 12:19 AM
Test drive 2012 Suzuki SX-4 A.W.D.. : 6 speed manual and C.V.T. ( w/ manual shift ) Hershey Off-topic / Other Cars / Everything else Discussions 7 09-30-2011 10:54 AM
Automatic or manual transmission bentjazz Fuel Economy Forum 31 03-03-2011 01:52 AM
Question: Didn't we have the Entire Service Manual in .pdf form? Shroomster Suggestions - Feedback - Questions 2 10-27-2008 12:18 PM
