Old 11-24-2014, 09:37 AM   #1
tiffany819
Drives: 2008 toyota yaris
Vent control
I went to switch my vents to defrost today and the knob will move but the vents won't move. Has anyone else had this problem or know how to fix this?
tiffany819 is offline   Reply With Quote
Old 11-26-2014, 07:34 AM   #2
ex-x-fire
Does the knob feel funny or easy to turn? Maybe the linkage came unhooked.
Old 11-26-2014, 11:19 AM   #3
^Exactly. That is a common problem. When the flappers in the airbox are cold they are stiff and hard to move, so when you crank the vent position handle the cable connector pops off the back of the dash knob.
To check it, pull the black vertical pieces off with your fingers, pull the radio trim straight back towards you, then do the same with the AC control panel.
vent control
air vent control nazier DIY / Maintenance / Service 0 07-05-2010 03:58 AM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
