Old 05-04-2009, 12:58 PM   #1
Syroyizhka
Syroyizhka's Avatar
Drives: 2007 Yaris Hatchback
Question Need help! Trying to run a wire from under the hood to the cabin!!!
I'm trying to run a cable from the newly purchased neons, from under the hood into the cabin of the car, only one problem , I don't know where to do it, I saw a bunch of cables going that way down by the clutch but, the hole looks imposibly small! any suggestions? this appears much harder in a smaller car than it was in my old nissan :) give me some hints please
by the way, the ending connector has a 1 wide connector on it, how am i gonna fit it through that little hole even if i do manage to do it somehow with a coat hanger ? :)
Syroyizhka is offline   Reply With Quote
Old 05-05-2009, 12:05 AM   #2
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
follow the main harness on the drivers side of the car. It is right behind the battery. Use a cable puller and push it in from under the dash.
Old 05-06-2009, 12:40 PM   #3
Syroyizhka
Syroyizhka's Avatar
where exactly does it come out on the inside?
Old 05-06-2009, 12:49 PM   #4
kurokoma-kun
Drives: 2007 Yaris HB
There's a good place in the passenger footwell.
Carefully pull up the carpet; its just tucked under the plastic trim pieces, and has velcro in one spot. Lift the white foam footrest and wooly mat below. Look for a rubber plug with a tube attached, up underneath the dash a bit and close to the center console--pop out the plug and you will find a nice 1" (or so) hole in the sheet metal.
It comes out at the bottom of the engine bay (below the header)... easy access and plenty of places to secure your wires out of the way.
I used this hole to install some gauge wiring, like you I had a good sized electrical connector to pass through the firewall. I simply trimmed the edge of the rubber plug to make room for the extra wire harness, and popped it back in.
Old 05-07-2009, 02:12 PM   #5
Syroyizhka
Syroyizhka's Avatar
a picture of the are at least to guide me in the right direction where to look would be nice :)
Old 05-07-2009, 03:32 PM   #6
kurokoma-kun
here yuh go homie
its on the left side of passenger footwell, looking at/under the glove compartment...pretty much the only rubber plug + tube yer gonna find under the carpet there looks like you don't even need to remove the white footrest or mat! I just remembered pulling all that shyt up for some reason
if you set a flashlight next to the hole, then look down into the back of your engine bay, you'll see right away where it comes out.
so what color neons?
Old 05-07-2009, 04:45 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
There is also a rubber stopper accessible from the engine bay, but you'll need to poke a hole in the carpet.
Old 05-08-2009, 05:06 PM   #8
Syroyizhka
Syroyizhka's Avatar
I got a multi color Neon system, with Red, Green, Blue, baby blue, purpulish, and yellow... they all have different blinking patterns, even to the sound of music, they can move at different speeds as well. Got it off ebay for 90 bucks shipped. Good deal, plus these are flexible, don't break or crack, look pretty legit. Thanks a whole lot for the pictures dude! you're my savior. I tried sticking the coat hanger from the engine bay behind the battery, but it was useless, I couldn't get it to go all the way through under the dash. But this is great access point! thanks again!
cabin wire run
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
DIY: Replacing Stock Mirrors redyaris DIY / Maintenance / Service 30 04-20-2016 03:03 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
