Old 06-21-2007, 04:51 PM   #1
redyaris
Shiny Chromey Coolness
redyaris's Avatar
DIY: Replacing Stock Mirrors
This DIY is another easy one (my specialty)...should take no more than one hour tops!
This DIY is for replacing your Yaris liftback stock mirrors. This is a great alternative if you have considered installing power mirrors or mirrors with LED turn signal indicators/parking lamps onboard. This is also an alternative to stick-on and replacement mirror covers.
1. Remove your door panel. Refer to the following DIY for instructions on this step: http://www.yarisworld.com/forums/sho...+panel+removal
2. The mirror is attached via 3 screws with nuts hidden behind three access holes.
3. Using a wrench with extension remove the 3 nuts from the mirror screws. Observe the base plate that holds the mirror on the car and placement of the 3 screws. Also note from the outside of the car the 3 holes the mirror uses for the screws.
***NOTE: Unless you have tiny fingers or are ultra careful you are guaranteed to lose at least a couple of these nuts in the door (Good news is if you do lose them they are easy to retrieve with a magnetic screwdriver and small needle nose pliers).
4. Remove the factory mirror. Sell on Ebay.
5. Install new mirror. I chose a chrome manual K6 style mirror with LED insert that illuminates in sync with the turn signals and parking lights. I
t came with 3 wires (black = ground/white = signal light/blue = parking light) The supplier had one available with a 3 hole base plate that fit the Yaris liftback perfectly. I threw away the 3 screws supplied and chose bolts instead with washers for a more secure install.
6. Reinstall the door panel wrapping the 3 LED wires under the rubber weather seal on the door to hold in place.
7. Run the 3 wires to appropriate locations (NOTE: you may need additional wire to complete this part). To access side marker turn signal light go thru the black trim piece in front of the mirror base).
7. Enjoy your new Yaris look with the new mirrors!!!!!!!
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
"Official" Yarisworld.com DIY Manual vodkalush DIY / Maintenance / Service 41 11-02-2023 11:47 PM
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Replacing stock deck - photo tutorial gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-06-2012 01:04 PM
replacing stock rims after the winter mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-24-2007 09:36 AM
