Old 05-26-2006, 09:31 AM   #1
gravylegs
Drives: 2007 Yaris Liftback RS
Replacing stock deck - photo tutorial
Hi people, while I was replacing my deck / door speakers I snapped a few photos with my phone. Might be useful to the more timid folks out there who don't like reefing on panels until you find the right one.
getting the stock deck out is as easy as 1-2-3.
1. Start with the center panel trims on the left and right of the stack. Pull at the bottom of each one, and follow it all the way up. Once you have them detached, you can either lay them on the dash, or disconnect them and set them aside. I let them dangle because I am lazy.
2. Starting at the top of the trim on the speedometer window, pull the trim so it detaches, and keep pulling evenly on both sides until the who thing comes off to the environmental controls. It is two pieces, but is easier to remove as one piece.
3. There are 4 easily accessible screws holding the deck in, just unscrew 'em and yank the deck out!
Putting a new stock deck in is NOT as easy as 1-2-3! I bought an echo mounting kit as mentioned by someone else on the board, and while the kit was useful to provide something of a "face", it wasn't very useful to actually mount a stereo. Here is what I ended up having to do.
1. Detach mounting brackets from the stock deck.
2. Widen holes in side of deck if required. I did this with a drill, but more out of frustration...
3. Mount stock brackets onto new deck.
4. Hook toyota wiring harness on onto new deck's wiring harness. (Saves you having to chop up the wires in your dash...ask if you dont know what this is about)
5. Plug everything in and test stereo out to ensure connections are good.
6. Mount the deck with the 4 screws.
7. NOW....use the toyota echo mounting kit....all I could do was to chop off the extra tabs, and then place it in "around" the new deck. It fits in there snugly.
8. replace all the dash parts, and you have a new stock deck that works! The only drawback is that the faceplate of the mounting kit does not COMPLETELY fill the hole in the dash. It is pretty close, and doesn't look TOO bad....but I will for sure be buying the proper mounting kit once it is available.
Hope this helps someone. Pulling off doors tutorial with pics coming soon.
Gravylegs.
gravylegs is offline   Reply With Quote
Old 05-26-2006, 09:46 AM   #2
Dylanby
Drives: RS 5-DR
You left out the finale. Where's the money shot? We don't get to see the end result
Dylanby is offline   Reply With Quote
Old 05-26-2006, 10:10 AM   #3
gravylegs
lol...oh yeah...money shot coming soon.
Old 05-26-2006, 10:55 AM   #4
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Thanks for sharing, man.
Idjiit is offline   Reply With Quote
Old 05-26-2006, 02:29 PM   #5
Leenis24
lil' town up north
Leenis24's Avatar
Drives: 07 Yaris LB 5 speed Meteorite
thank you for this, i was wondering how to go about pulling things off. Sweet post, like to see those other pics as well.
Leenis24 is offline   Reply With Quote
Old 05-31-2006, 12:21 AM   #6
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
yeah, i'm wondering how well the echo trim fits in.... let's see
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 08-04-2006, 01:37 PM   #7
Kiteless
Kiteless's Avatar
Drives: US 2007 Yaris Liftback 5MT
Hey man. Great post. I was hoping to see what things looked like with the stock stereo pulled out. After what you said about the Echo dash kit, that makes me all the more wanting to wait for the proper Yaris dash kit. Aparewntly Metra keeps saying "2 more weeks". I dont understand what is taking so long. ;p
Kiteless is offline   Reply With Quote
Old 08-04-2006, 05:27 PM   #8
twixt
Drives: 07 LB,04&06 ninja 636
Send a message via AIM to twixt
i find installing the left side flasher rubber thinger is a pain because if it is a little outa wack the flasher button will stick.
twixt is offline   Reply With Quote
Old 08-04-2006, 07:13 PM   #9
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Thanks. That helps a lot.
C'mon Metra!
Old 08-05-2006, 01:23 AM   #10
johnnyfive
johnnyfive's Avatar
wow, that is quite a bit different than the sedan...same basics though..
Old 08-08-2006, 07:32 AM   #11
SmellyTofu
好多人&
Drives: .
Props for this thread. Very easy to follow.
Old 08-14-2006, 03:14 AM   #12
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Gravylegs do I have your permission to post your tutorial to the Greek forum dedicated to Yaris???
Check it out www.yarisclub.gr
EDIT:Do you have any tutorial on how to change the speakers?
Old 08-14-2006, 12:42 PM   #13
iloveyarisRS
Drives: Yaris RS
wow.............nice........thx for sharing
iloveyarisRS is offline   Reply With Quote
Old 08-14-2006, 01:55 PM   #14
Linkseal
Drives: DBA-NCP91
Send a message via MSN to Linkseal
Thx for sharing the info and Pics...now I have sth to follow when I am gonna do mine...
But if anyone could share the pics and instruction on how to take out and front and rear door panels to change the speakers...Plz
Linkseal is offline   Reply With Quote
Old 08-14-2006, 03:19 PM   #15
gravylegs
Sure, go nuts with the tutorial! Glad people actually find it useful. I actually just replaced the speakers this weekend, and tho I did take pictures I just need to throw them up here. I'll do that in the next day or so.
Old 08-15-2006, 07:47 AM   #16
Katana
Katana's Avatar
Tnx for your approuval.
I will mention your name to the greek forum.
Please post the speakers tutorial too.
Old 09-02-2006, 03:56 PM   #17
Violin
Violin's Avatar
I hope I'm not stepping on your thread here, but I just installed mine and figured it made sense to put these here rather than having two threads.
These sure help. I have them as pdf files. If anyone can host them, I'll email them to you.
(don't remove the gauges - step 5)
(don't remove a/c control panel)
Before you start, disconnect the battery ground.
Remove left side trim (start and bottom and work up):
Same for the right:
Unplug both and set aside:
Remove instrument gauge trim:
This is what the clips look like:
Remove the ventilation trim (start at top):
Ready to remove stock radio:
Remove 4 screws, pull out stock radio and unplug:
This connector will not be used (for iPod):
I used the metra smart harness (no soldering):
Put new head unit in metra kit:
Plug in new head unit (antenna too):
Install with 4 screws:
Replace gauge and ventilation trim:
Plug in and reinstall left and right trim:
Install head unit face plate:
Reattach battery ground and enjoy!:
Old 09-02-2006, 04:19 PM   #18
Katana
Katana's Avatar
Nice info there Violin.
Can someone post a tutorial on how to remove the OEM speakers?
