#19 | |
Shiny Chromey Coolness
Drives: 2007 Toyota Yaris Liftback Join Date: Feb 2007
Im a simple man and I did what I thought was the easiest, most direct wiring (to the wire source I knew I needed). No pulling trim pieces either and routing wire in the cabin.
Bringin the Bling to Yarisworld |
#20 | |
Violin I ran the 3 mirror wires (blue/white/black) from an interior access hole from the mirror mounting on the interior door panel, ran them up and under the top trim piece of the door arm rest, wrapped the wire around the corner of the door (I could have drilled an access hole but im lazy), and put the door panel back on to hold the wire. I then tucked the 3 wires under the rubber weatherstrip. I also put a couple of pieces of sticky black duct tape to hold the wires to the door to prevent pinching when opening and closing. I connected my extension wire then to all 3 mirror wires. I ran these 3 extensions into the engine bay and side marker lamps on each side by tucking them under the big black triangular trim piece directly in front of the mirror (no need to remove it even). (If you pry it up a little from the bottom youll see the fender area and the side marker lamp). I was able to reach my manly arm into the fender area from the front of the car to grab the extension wire and fish it to the side marker lamp and into the engine bay for connection to parking lamps and ground bolts. Its surely NOT factory but it works....and if anyone opens my door to look at wires they are anal.
#21 |
That would be me.
#22 |
Passin' The Gas...Station
There is a rubber boot towards the lower half of the forward edge of the door. It's for the speaker wires / power wires etc etc. Could you run the wires through there into the cabin?
Chuck
MY Gas Station Attendant Misses Me...![]() Chuck |
#23 |
Yes you could if you were anal.
#24 |
That would be me.
#25 |
LOLOLOL Violin. Remind me never to open my doors around you.
#26 |
![]() ![]() Drives: integra Join Date: Apr 2007
I like your Cherubs ;-).
#27 |
![]() ![]() ![]() Drives: None Join Date: Mar 2007
redyaris, your car looks awesome. You actually understand the concept of trim (red with chrome, not red with heaps more red). Keep up the great mods.
#28 |
Why thanks Edd!!! Im one of the maybe 2 people who like chrome here.
#29 |
Heh heh, those are the 4 Seasons (Spring, Summer, Winter, Fall). My wife loves statuary....makes for a classy picture...something I can always use more of!
#30 |
Look mum no stars!!
ur fender repeater isnt working now??? since u transfered that to ur mirrors??
| Yarisworld.com DIY Manual v3 | vodkalush | DIY / Maintenance / Service | 101 | 06-25-2024 12:10 AM |
| "Official" Yarisworld.com DIY Manual | vodkalush | DIY / Maintenance / Service | 41 | 11-02-2023 11:47 PM |
| DIY - Sparco Race Seat Install | Idjiit | DIY / Maintenance / Service | 16 | 08-14-2017 09:15 PM |
| Replacing stock deck - photo tutorial | gravylegs | In Car Entertainment + Electronics (audio / video / alarm) | 39 | 02-06-2012 01:04 PM |
| replacing stock rims after the winter | mikeukrainetz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-24-2007 09:36 AM |
