Old 02-25-2015, 09:28 PM   #1
Echo86
Drives: 2003 Toyota Echo
Two Problems
Hi All, it's been a cold winter here in Canada, but the car only recently did not start on the first try. Now I have to delay a few seconds before trying again. Usually it starts on the second try. I can tell the temperature makes it worse. I replaced the plugs and air filter in December. That is it. I checked the ground on the battery. It is secure. That's problem 1. Problem two is the power since repairing the exhaust. It had separated at the muffler flange. I plug welded the pipe together, it wasn't the greatest job and some wire may have gotten stuck in the pipe. The muffler makes a soft whooshing sound when the throttle is release during gear changes. I will do a proper repair with a new piece of pipe later. At least the rattling sound of the exhaust knocking about is gone. Cheers
Echo86 is offline   Reply With Quote
Old 02-26-2015, 09:28 AM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
when you attempt to start does the starter drag at all? also how old is your battery? i personally find the oem battery to be garbage in cold climates. mine only lasted 3 years.
Old 02-26-2015, 11:26 AM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Someone else had the first issue here...
http://www.yarisworld.com/forums/showthread.php?t=53853
...but it turned out to be a tightness of the - and + battery terminals thing.
Old 02-26-2015, 11:27 AM   #4
fnkngrv
fnkngrv's Avatar
do you have a multimeter or voltage meter to check what it looks like when ypu engage the starter?
Old 02-26-2015, 11:31 AM   #5
sheekeebut
Minimalist
Drives: 07 silver sedan
Did you pass by your local crappy tire for a battery check?
sheekeebut is offline   Reply With Quote
Old 02-26-2015, 01:05 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
On the contrary, it work very well in cold climates.
I still have my original panasonic battery from 2006.. It's about die this year, but it's going to last me through the summer when temps warm up.
Old 02-26-2015, 01:23 PM   #7
sheekeebut
Minimalist
My 07's original battery has managed to start up on the first time every time even up to now, in -24 C cold. I wouldn't say the battery quality is bad or good, but I'm sure my conservative driving habits have kept it going all this time. My thing is to make sure the car gets an easy 10 km after every cold start.
Old 02-26-2015, 11:30 PM   #8
Echo86
No, but it does pretty much the same thing at each start. Acts more like there's a bug in the system than sufficient power. The battery is going on 3 years though. I'll have it checked.
Old 02-27-2015, 06:22 AM   #9
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Another question, what kind of oil are you running?
Lower-viscosity grades, make it easier for your engine to start from cold because they present less resistance to moving parts and hence take less power from your battery.
Old 02-27-2015, 04:45 PM   #10
Echo86
Conventional oil. Don't know the viscosity, just the regular stuff Mr. Lube puts in.
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Yaris problems heavenswaitin DIY / Maintenance / Service 3 11-02-2011 01:08 PM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
