Old 04-25-2015, 10:45 PM   #1
ipwnr
Drives: 2003 toyota echo 1.5l manual
echo throttle body swap
got the larger 50mm tb off a 98 corolla and with some small modifications got it to bolt up to the manifold.
out with the old
in with the new
coolant lines line up
throttle hooked up
engine bay after install
and the iacv is stuck open
i did a temp fix for the high idle by filling the iacv port with silicon, only problem with that is the idle will no adjust if theres a load at idle and it will not idle cold.
ipwnr is offline   Reply With Quote
Old 04-26-2015, 06:58 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Did you try backin out the throttle stop screw first?
Old 04-26-2015, 02:30 PM   #3
ipwnr
Yes I tried backing out but the screw was seized. Its just temporary until I can get another throttle body
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
1.8L throttle body dimensions drawing CrankyOldMan DIY / Maintenance / Service 5 03-09-2016 09:30 PM
wtb stock throttle body , cheap blacksandiegovitz Willing to Buy by private party 0 09-21-2012 10:32 PM
Throttle Body spacer? jekqmb Performance Modifications 2 10-04-2011 11:02 PM
FS: 1ZZ 05 Corolla Throttle Body FunctionSpec Items for Sale by private party 15 05-26-2010 03:23 PM
