Old 10-04-2011, 08:36 PM   #1
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Throttle Body spacer?
Will our throttle bodies bolt to a 1nzfe XA/XB throttle body spacer?
Old 10-04-2011, 09:52 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I don't think they use the same bolt pattern. From what I can find on google, it appears that the yaris has a 4-bolt pattern and the xB uses a 3-bolt pattern. Take a look at this one from a Matrix that bolts on to the yaris directly vs one from an xB that is compatible with the 1ZZ engine. As far as I can tell, the xB is a first gen, 1nz-fe engine. The difference is the intake header, which is where the TB mounts up.
If you're looking to get one for the yaris, try looking at the corolla as well: http://www.amazon.com/Street-Perform...7780717&sr=1-1
Old 10-04-2011, 11:02 PM   #3
jekqmb
Thank you!
1ZZ Throttle Body Spacer tk-421 Performance Modifications 34 07-11-2017 09:48 PM
FS- 1ZZ Throttle Body, Spacer, NST SSK MGargano Items for Sale by private party 9 09-01-2010 08:48 PM
Throttle Body Spacer?? ozmdd Performance Modifications 11 09-30-2009 10:57 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
