Old 08-09-2017, 07:08 PM   #1
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Train Horns on a Yaris
Why? Because I can LOL
I will go over a few of the details. I have to say that for a kit that doesn't use a massive air tank and isn't $500+ I am very happy and impressed.
I wanted the horns to not be visible, and the compressors need to be mounted as far from the engine as possible. Seeing as the yaris engine compartment is short on room, i decided to mount the horns on the steel bumper reinforcement and the compressors/relays on the plastic panel next to the radiator. For the horns I used one of the existing holes on top of the bumper and drilled a hole on the bottom, and mounted the horn themselves on an aluminum bar.
for the two compressors I drilled and mounted them on the outside of the plastic panel. On the backside i used an aluminum bar to help brace the plastic. I ended up having to trim the bumper cover some, but this can be avoided if you mount the compressors lower than I did. Measure twice cut once, do as I say not as I do
I mounted the relays on the backside, ran my wiring and air lines. For power I chose to buy a separate distribution block for boats. I wired the button up and ta da! Done
And a quick clip
https://www.instagram.com/p/BXjYWMuFwaR/
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 08-10-2017, 10:55 AM   #2
bronsin
bronsin's Avatar
Reminds me of the time as a kid I came across a real truck air horn in a junk yard and got it for $5. We disconnected my friends fathers co2 cannister from his beer tap at the bar and blasted ourselves silly!
Might get one of these:
https://www.harborfreight.com/bad-bo...orn-94117.html
Old 08-11-2017, 07:11 AM   #3
Rigaud
Drives: 2009 Yaris
TRANSPORTATION CODE
TITLE 7. VEHICLES AND TRAFFIC
SUBTITLE C. RULES OF THE ROAD
CHAPTER 547. VEHICLE EQUIPMENT
SUBCHAPTER J. PROVISIONS RELATING TO WARNING DEVICE REQUIREMENTS ON VEHICLES
Sec. 547.501. AUDIBLE WARNING DEVICES. (a) A motor vehicle shall be equipped with a horn in good working condition that emits a sound audible under normal conditions at a distance of at least 200 feet.
(b) A vehicle may not be equipped with and a person may not use on a vehicle a siren, whistle, or bell unless the vehicle is:
(1) a commercial vehicle that is equipped with a theft alarm signal device arranged so that the device cannot be used as an ordinary warning signal; or
(2) an authorized emergency vehicle that is equipped with a siren, whistle, or bell that complies with Section 547.702.
(c) A motor vehicle operator shall use a horn to provide audible warning only when necessary to insure safe operation.
(d) A warning device, including a horn, may not emit an unreasonably loud or harsh sound or a whistle.
Source(s):
http://www.statutes.legis.state.tx.us/Do...
Old 08-11-2017, 07:58 AM   #4
nortonfb
Drives: 2007
"Arbitrary & capricious" law.
Most likely if challenged would fall. Not specific, two individuals may have two
different standards.
Blow away!
nortonfb is offline   Reply With Quote
Old 08-11-2017, 12:19 PM   #5
hotracer_05
Hmm, I see...
Thats why I wired it to a separate button and not the factory horn
Old 08-12-2017, 01:05 AM   #6
SirDigby
Drives: 2007 yaris 3 door
Originally Posted by Rigaud View Post
TRANSPORTATION CODE
good thing it's not a siren, whistle, or a bell and can be heard at a distance of 200ft. and also, it's texas. rednecks do so many retarded things with their trucks, i don't think the police will car about a horn on a little car...
Old 08-12-2017, 04:35 AM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This is where they would get you, potentially. The fact that these style of horns are used on commercial vehicles means you're probably OK if it goes to court.
Old 08-17-2017, 05:04 PM   #8
davino1966
Drives: yaris
I had Hornblasters on both of yaris. Had a 2010 and a 2014 se. Love them horns.
Sent from my SM-G950U using Tapatalk
davino1966 is offline   Reply With Quote
Old 08-17-2017, 06:10 PM   #9
tmontague
tmontague's Avatar
love this
Old 08-17-2017, 06:36 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
Way back when, I installed Ferrari air horns on my Datsun 240Z. They were pretty loud.
Initially, I hooked them up to the factory horn button and disconnected the OEM horn. I soon discover that a very short delay before blast was actually dangerous. So, I wired both horns to overcome that problem.
Old 08-20-2017, 06:21 PM   #11
coolguyndc
Drives: 2012 Yaris LE
Where did you pass the button trigger wire trough the firewall?
coolguyndc is offline   Reply With Quote
Old 08-21-2017, 12:31 AM   #12
hotracer_05
Hmm, I see...
Where the washer fluid line goes through on the passenger side
Old 08-21-2017, 04:22 PM   #13
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
very cool love it
Old 08-21-2017, 04:23 PM   #14
justanotherdrunk
Drives: 2016 SE
TRANSPORTATION CODE
Source(s):
Old 05-28-2023, 09:56 PM   #15
allmybase
Drives: 2007 Yaris
Signed up just to ask - where'd you find that sweet yellow dash button? It looks made-to-fit!
allmybase is offline   Reply With Quote
Old 05-28-2023, 10:06 PM   #16
sh0rtlife
pretty sure thats a standard off the shelf "arcade" button..they come in a few sizes and the good ones are "click" switches
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
