Old 05-09-2016, 04:28 AM   #1
rabbito
rabbito's Avatar
Tire or Rim issue?
i was running horrible Bridgestone tires 185/60/15 that came on my stock TRD rims (15x5.5)...after i did some performance modification i changed my tires to Hankook V2 195/50/15 which is pretty good..i have dropped about 1 inch due to shorter tire wall..i am not stil confident through curves on high speed 100km+ (maybe im pissed because i lost to BMW 5 series during corners)...what is the issue? i have front tower strut and rear sway with performance strut and shock all the way around droped 1.5 inch..
do i need a wider width rims..?
or better tires?
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 05-09-2016, 05:08 AM   #2
cyberguy
Drives: d4d
Originally Posted by rabbito View Post
i was running horrible Bridgestone tires 185/60/15 that came on my stock TRD rims (15x5)...after i did some performance modification i changed my tires to Hankook V2 195/50/15 which is pretty good..i have dropped about 1 inch due to shorter tire wall..i am not stil confident through corners on high speed 100km+ (maybe im pissed because i lost to BMW 5 series during corners)...what is the issue? i have front tower strut and rear sway with performance strut and shock all the way around droped 1.5 inch..
or better tires?
are you sure that your rims are 15x5? if yes then 195 is too wide for your rim. I use toyo r1r 195/50/15 with a 15x7 rim and they are ideal for my car. Also I am much faster in turns than with the stock 185/60/15
cyberguy is offline   Reply With Quote
Old 05-09-2016, 05:14 AM   #3
rabbito
rabbito's Avatar
sorry dude, its 15 x 5.5...actually 195 is the widest fit (check the tire chart) for 5.5..185/60/15 is from the factory...
Old 05-09-2016, 07:38 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
a 195 on a 5.5" rim is going to be pulling the sides of the tire up. You need to move up to a 7" wide rim to maximize the tire contact patch.
Old 05-21-2016, 05:09 AM   #5
rabbito
rabbito's Avatar
actually its doing fine without an issue..stock is 185..i just plus size to 195...they have tire chart, you can use the chart.......
Old 05-09-2016, 08:22 AM   #6
I hope you actually mean curves!
Old 05-09-2016, 10:05 AM   #7
rabbito
rabbito's Avatar
sorry curves.....
Tire rotation question vasonline Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-15-2016 10:42 AM
Costco Tire Damage Issue nkaufman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-16-2015 06:48 PM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
