Old 03-14-2015, 10:05 AM   #1
nkaufman
Costco Tire Damage Issue
For my 2010 Yaris sedan with P185/60R15 tires:
Got Michelin Defender 90K mile warranty tires from Costco about 4K miles back.
Now one of the rear tires got damaged, metal piece pierced sidewall. Costco wasn't getting the Michelin tires so wanted to replace both the rear with Bridgestone.
If I insist of Michelin then they will go outside the regular channels and get only ONE tire and replace the damaged one saying that for a 90K mile tire, 4K driven miles will not make much of an impact.
Which alternative is better or if neither then what should I propose to them?
Thanks.
nkaufman is offline   Reply With Quote
Old 03-14-2015, 11:12 AM   #2
bronsin
bronsin's Avatar
Thanks.
Either way is fine. I personally would go with the single new Mich.
Old 03-14-2015, 11:31 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Get one new Michelin.
Old 03-14-2015, 02:14 PM   #4
Get 1 new. 4k miles is nothing especially it is a rear tire..
Old 03-14-2015, 02:49 PM   #5
MUSKOKA800
MUSKOKA800's Avatar
Do the matching Michelin. It's never good to have mixed brands in play.
Old 03-14-2015, 04:49 PM   #6
nkaufman
Thanks everyone for the input.
So basically get the ONE new Michelin because mileage is so less on the tires.
What would the strategy be if tires had say 30K on them and one tire gets damaged beyond repair? Replace 2 on the same axle or all 4?
Old 03-14-2015, 06:48 PM   #7
Usually is they are worn less than 1/2 thread, I would just get 2 new.
If you are on your last season or 2 with them, I would get all 4 new.
Old 03-16-2015, 06:48 PM   #8
nkaufman
Thanks everyone for their input.
Got Costco to replace one tire only. Hopefully all would be well.
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
Question on Wheel and Tire soup1207 DIY / Maintenance / Service 1 05-24-2013 10:11 AM
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
