Old 01-31-2018, 01:50 PM   #1
Janviernes
Drives: 06 5door
5-Door Rear Washer Fluid
Hello, I have an 09 5-door and I'm hoping to disconnect the rear washer fluid hose, and remove the nozzle on the hatch to put something else in its place. Anybody know where I can find the hose routing to the rear so that I can disconnect it or clamp it off?
Also any tips on removing the rear wiper itself would be appreciated.
Janviernes is offline   Reply With Quote
Old 01-31-2018, 04:48 PM   #2
Ghastlyship
Drives: 2015 Toyota Yaris Hatchback
Search for the diy of the horizontal to vertical wiper mod for rear wiper removal. It has pictures. Not sure about hose routing. Likely it’s routed over the roof upholstery.
Ghastlyship is offline   Reply With Quote
Old 01-31-2018, 11:41 PM   #3
Janviernes
Drives: 06 5door
Thanks, that helps some! :)
I'm hoping to locate the source of the hose in the engine bay so I can cut it off there and not have stagnant fluid in the line forever. But I'll check in the sills and pillars if that doesn't work out.
Old 02-01-2018, 11:25 AM   #4
Ghastlyship
Best place to start looking would be the washer fluid reservoir, for obvious reasons. I don't think having stagnant fluid in the line would be an issue. It doesn't take much to flush it out and AFAIK it doesn't go bad like other fluids in cars.
What are you replacing the nozzle with? Are you deleting the rear wiper and washer nozzle?
Old 02-01-2018, 04:16 PM   #5
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
The hose runs from the washer tank under the bumper on the passenger side through the body of the car (I believe along the floor but I'll have to check) to the back, up the D pillar to the center into the tail gate.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Inexpensive fix for low windshield washer fluid light stiuck on Toolaholic DIY / Maintenance / Service 5 04-21-2020 02:46 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Washer Fluid & Other Questions vaironl DIY / Maintenance / Service 1 11-16-2013 01:25 PM
Windshield washer fluid Twistoffate0817 General Yaris / Vitz Discussion 5 05-12-2010 12:47 PM
Washer fluid warning light "Backwards" Snyprwlf47 General Yaris / Vitz Discussion 2 02-15-2010 08:47 PM
