Old 05-11-2010, 03:50 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Windshield washer fluid
Hello guys,
I was wondering If it would do any harm to use windshield washer fluid with de-icer right now. It is now warm out, and will remain hot for the summer. Is it fine to use the de icer windshield washer fluid?
Twistoffate0817 is offline   Reply With Quote
Old 05-11-2010, 04:13 PM   #2
127.0.0.1
Originally Posted by Twistoffate0817 View Post
Hello guys,
it is fine
Old 05-12-2010, 04:45 AM   #3
RedRide
RedRide's Avatar
Yes, it's designed for year round use.
Old 05-12-2010, 10:58 AM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
It is fine as in it won't ruin your windshield, but it's not so good for you or your passengers if the fumes are inhaled via open windows or vents, or for your local environment if any of it is spilled or over-sprayed. There is some toxic stuff in that fluid.
I just make my own fluid with 2 tablespoons of vinegar in a gallon of water, and 1-2 drops of lavender oil. No detectable foul odor, food grade, fully biodegradable, a few pennies for each gallon and all throughout last winter I never had it freeze in the lines or on my windshield, even on snowy and windy days at high altitude (my engine grille block likely helped with that, so YMMV).
- Brian
Share the Road
Old 05-12-2010, 11:55 AM   #5
it's isotopyl kind of alcohol in there. Anyhow, it smells the same.
Old 05-12-2010, 12:47 PM   #6
Emerge
On a trek to upgrade...
Drives: 2003 Echo Coupe
I just make my own fluid with 2 tablespoons of vinegar in a gallon of water, and a single drop of lavender oil. No detectable odor, food grade, fully biodegradable, a few pennies for each gallon and all throughout last winter I never had it freeze in the lines or on my windshield, even on snowy and windy days at high altitude (my engine grille block likely helped with that, so YMMV).
That's sick dude.
Emerge is offline   Reply With Quote
No Windshield Washer Fluid Light captainm27 General Yaris / Vitz Discussion 20 12-18-2015 05:49 AM
Adjusting Windshield Washer Jets N9QGS DIY / Maintenance / Service 7 06-08-2010 10:10 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
