Old 02-27-2010, 07:21 AM   #1
captainm27
Drives: 2008 Sedan A/T Silver
No Windshield Washer Fluid Light
Today I ran out of Windshield Washer Fluid, but my light never came on. I have a 2008 Sedan. Was it just never designed to turn on? I can see the outline of the light when the sun strikes the dash.
captainm27 is offline   Reply With Quote
Old 02-27-2010, 08:19 AM   #2
nemelek
DWEED
nemelek's Avatar
Mine works.
Old 02-28-2010, 06:12 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Works on my 08 sedan..
Old 02-28-2010, 06:43 AM   #4
ddongbap
My blinker fluid is low, but I can't find the light.
Old 02-28-2010, 11:24 AM   #5
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Assuming you did actually run out (and a hose didn't fall off the pump, and you can hear the pump working, and the tank is actually empty), maybe your sensor is stuck or something. Take it to the dealer, the warranty wasn't free, doesn't hurt to use
BuildCode is offline   Reply With Quote
Old 02-28-2010, 03:06 PM   #6
captainm27
Good idea BuildCode. I actually did run out, because I just filled it up and it works perfectly again. Maybe I will tell the dealer to look into it.
Old 02-28-2010, 03:37 PM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Didn't you get the recall notice to have it repaired?
Old 02-28-2010, 04:29 PM   #8
BailOut
Steals terrorist's lunch
BailOut's Avatar
AFAIK you only get a warning light if your car has the "all weather" package. Are each of you sure you have that?
- Brian
Share the Road
Old 02-28-2010, 06:28 PM   #9
BuildCode
BuildCode's Avatar
Reallyyyyy. That's pretty cheesy.
Old 02-28-2010, 10:54 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
So... you must have the all-weather package to get a low washer fluid light?
Old 02-28-2010, 11:22 PM   #11
BailOut
BailOut's Avatar
*nod* It's a bullet on the list of things in the All Weather package. I remember it reading like:
"Larger washer fluid reservoir and a low fluid level indicator light."
- Brian
Share the Road
Old 03-01-2010, 12:29 AM   #12
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
if that is true, that is some bs...
Old 03-01-2010, 12:50 AM   #13
BailOut
BailOut's Avatar
Here it is. Note that it is indeed part of the All Weather package:
- Brian
Share the Road
Old 03-02-2010, 06:53 PM   #14
captainm27
Bailout, if that's true, how come I still see the outline of the light? Is that just some kind of default setup for all Yaris Dash?
Old 03-02-2010, 07:15 PM   #15
BailOut
BailOut's Avatar
I imagine so, just like some of our clusters have cruise control indicators whether we have that package or not, and just like our dashes have the cutout/pop-out space to mount a push start button even though it isn't offered in NA.
It is too expensive for a manufacturer to have to design, build, maintain and support too many variations of anything in a vehicle.
- Brian
Share the Road
Old 03-02-2010, 07:26 PM   #16
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Haha wow that is hilarious. As if you need the all weather package for that to work. My guess is they just did not include the proper sensor in the washer tank, though. Or maybe the larger tank comes with the sensor.
Meh. I believe the all weather package is standard here in Canada, which is what I got ...
devinlamothe is offline   Reply With Quote
Old 03-02-2010, 07:29 PM   #17
captainm27
Wow! I didn't know about the Push Start. Cool....sounds exciting.
Old 03-03-2010, 03:58 PM   #18
CtrlAltDefeat
I ♥ Yaris
you should check out this thread:
http://www.microimageonline.com/foru...make-work.html
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Washer fluid warning light "Backwards" Snyprwlf47 General Yaris / Vitz Discussion 2 02-15-2010 09:47 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 08:26 PM
Low washer fluid light auxmike DIY / Maintenance / Service 3 12-14-2008 02:47 AM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 02:47 PM
