Old 03-08-2018, 10:46 PM   #1
SirDigby
Drives: 2007 yaris 3 door
New Tachometer
i just got another tachometer. this one is too nice to build a pod on, so i'm going to build a gauge cluster and install it properly.
Old 03-09-2018, 06:27 AM   #2
Runethecursed
Drives: 2009 Yaris S
Doesn't go high enough... #aboutthatrotarylife
Runethecursed is offline   Reply With Quote
Old 03-09-2018, 03:29 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I wouldn't mind having a tach again.
Ha.
On Instagram
On Wheelwell
Old 03-10-2018, 05:27 PM   #4
SirDigby
rev limiter is at like 6500...
it has a 1NZ-FE. a 20b would be nice, but correcting mazda's mistakes are expensive. the car modification would be expensive. maybe someday....
Old 04-10-2018, 01:43 AM   #5
Dliverance
Drives: 2012 Black sand pearl <3
Where are you planning to put the gauge cluster? I’ve been thinking about putting one above my steering wheel in the removable compartment on mine. It would be nice to have a bezel for it though
Dliverance is offline   Reply With Quote
Old 04-10-2018, 10:03 PM   #6
SirDigby
right now i built a pod on the back of a little cheap-o and mounted it in the glove box.
i think i'm going to get a thick piece of plexiglass and bend it into an "L" shape and frame in some side pieces. then i'm going to cut a square out of the glove box to mount. behind the door, i am going to mount a power strip and a ground strip to make powering gauges and other things up there easier.
Old 04-12-2018, 12:12 PM   #7
Runethecursed
I made a backing plate for mine and removed teh glovebox in full. i need to spend more time on it as i want to redesign how it looks and works,
Old 04-13-2018, 03:12 PM   #8
B.B._07
Drives: 07 5dr
I think a much cleaner solution is to get a OE Canadian instrument cluster which includes a tachometer. The only drawback is the speedometer is in km/hr with miles/hr shown below in a smaller font.
Old 04-16-2018, 09:24 PM   #9
SirDigby
yeah, but the Canadian one still does not have a water or oil gauge. the main concern is water temp. i did not want to goop filler on the nice water gauge ether, so the best option is to build a cluster onto the glove box. plus, it's way more fun to build stuff than to plug stuff in...
gauge, racetech, tach, tachometer
Tachometer install 07YarisUS Cosmetic Modifications (Exterior/Interior) 3 02-22-2016 12:44 PM
Tachometer 09BoostedVitz Performance Modifications 12 07-21-2011 09:48 PM
Manual with no tachometer tips maineyaris General Yaris / Vitz Discussion 10 02-01-2011 04:42 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
