Old 06-08-2011, 11:18 AM   #1
09BoostedVitz
Drives: 09 Yaris Hatchback
Tachometer
Hi I have a 09 yaris hatchback 5spd and I hate the fact that it dosent have a standard tachometer. I want to buy a digital tachometer but I dont want to buy those big 5" tachometer. I want something that is small and digital that can display the rpm's. Anyone that has a 5pd yaris without a tach, what are you guys using?? Thanks for your replies
09BoostedVitz is offline   Reply With Quote
Old 06-08-2011, 11:21 AM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I don't know if anyone has installed a digital tach, but there are plenty of examples of analog tachs in the DIY forum - just go there and search for Tach.
Old 06-08-2011, 11:25 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yea.. This has been addressed many times.
Do an Advanced search and look up key words: tach, tachometer, rpm guage
I think this post says it best:
http://www.yarisworld.com/forums/sho...ach+tachometer
Old 06-08-2011, 04:11 PM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
there are literally thousands of options for tachs. The easiest way is to go to a local racing shop and just ask, they have books full of them.
Colin Chapman disciple
Old 06-08-2011, 04:44 PM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
one thing about the digital tach is the refresh rate. I used an ultragauge for a while but the refresh rate on it sucked. that is a big reason for the analog tach. I went with a 3 3/4" one just so I could see it easily. it reacts quickly so you know what the motor is doing.
here is a thread I started. http://www.yarisworld.com/forums/showthread.php?t=34360
within it is also a how to on how to put one in yourself. there are a million options. find one that meets your needs (and budget). take your time and make it look clean, all is good.
Old 06-08-2011, 06:02 PM   #6
ilikerice
ilikerice's Avatar
I think the ultraguage is not a good reason not to get a digital.. remember, the LF-A uses a digital tach because the analog is too slow to catch up with the engines rpm's. If you dont go cheap and get a really good digital tach, I think it would work better.
But lets be real, what yaris out there is going to going to have a engine that responds that fast to throttle. lol
Old 06-08-2011, 06:45 PM   #7
Autometer makes very nice digital tachs. I had one in my tC, got very used to it.
Old 06-08-2011, 07:16 PM   #8
BEEF
BEEF's Avatar
maybe it is personal preference. if digital is the way you want to go, there are plenty of them out there too. you can easily install one on your yaris. took me about 2 hours (mostly because I am a bit anal). I went ahead and tried to make it pretty at the same time.
it really isn't hard to do.
and yea, my yaris doesn't rev near fast enough to outrun the analog tach. lol
Old 06-09-2011, 08:13 PM   #9
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I went with an ecometer-plug in to the OBD 2 port and mount it. Done. Digital tach. Refresh rate is 2x a second. Been good enough for me but it depends on how fancy/precise you want to get. MI has them for about $60 I think.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 06-09-2011, 08:21 PM   #10
Lil Abner
Drives: 2009 3dr LB Manual
I did this:
Old 06-10-2011, 02:45 AM   #11
xbr3akd0wnx
Meow
Drives: 2008 Yaris, White Hatchback
Originally Posted by Lil Abner View Post
I did this:
OHHH MY GODDDDDD GENIUSSSS GENIUSSSSSS!!!!!! HOW DID YOU DO THIS AMAZING THING?!
xbr3akd0wnx is offline   Reply With Quote
Old 06-10-2011, 08:22 AM   #12
Lil Abner
HA, thanks. I just took an Autometer gauge I bought, cut everything off of it, leaving just the circuit board assembly and needle. Found a piece of PVC that I used as a new case. Then built the front panel from acrylic. I think anyone that's messed around with plastics before could do it. It just took time and patience to get it to fit right.
Old 07-21-2011, 09:48 PM   #13
Who_Is_SB
Who_Is_SB's Avatar
Drives: 2009 Yaris 3DR HB
Send a message via AIM to Who_Is_SB
Heres mine, 3", easy to read but not large to the point where it overpowers everything. Glowshift Elite 10 Colour.
Who_Is_SB is offline   Reply With Quote
Manual with no tachometer tips maineyaris General Yaris / Vitz Discussion 10 02-01-2011 04:42 PM
STRI DSD-SLM II 60mm Amber Tachometer arunto Items for Sale by private party 0 02-24-2010 09:52 AM
keyless entry with tachometer matash In Car Entertainment + Electronics (audio / video / alarm) 12 01-29-2010 03:36 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
