Old 04-23-2020, 12:36 PM   #1
Jack Yak
Drives: Yaris 1.3 07
Better Tyres front or rear ?
Hi Everyone,
I'm about to change my tyres - i have 07 sedan -
My old set up was Kumho Ecsta Ku31, honestly i was very satisfied with this tyre performance and handling during cornering.
i got a good deal on Michelin Pilot sport 3 but i can't afford having 4 tyres of them it's a bit expensive
so i decided to go 2 tyres Michelin ps3 and 2 tyres Kumho Ecsta PS31 which is considered as a sport tyre as well and my previous experince with Kumho Ecsta is really nice.
So, should i have the Michellin (which is providing better grip / traction) on front or rear ?
i'm looking for better performance / handling
(i'm having BC coilover suspension installed)
Tyre size : 16R 205/50
Jack Yak is offline   Reply With Quote
Old 04-23-2020, 02:51 PM   #2
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I would recommend all 4 tires be the same. If you can't afford all 4 of them, then buy 4 that you can.
NYC-SE is online now   Reply With Quote
Old 04-23-2020, 03:06 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
If you are only replacing 2 tyres, then the new ones go in the rear. It doesn't matter if the car is front wheel drive or rear wheel drive.
Old 04-23-2020, 07:11 PM   #4
NYC-SE
NYC-SE's Avatar
If I'm understanding correctly the OP is replacing all 4 tires, 2 sets of 2, from different manufacturers. I don't see the point of doing so. Better to have common behavior from the same tires at all 4 corners IMHO.
Old 04-23-2020, 08:07 PM   #5
kimona
kimona's Avatar
Yes, I just reread the post and indeed that seems to be the case!
I would have to agree with you that it would certainly be best to install 4 identical tyres.
If the OP insists on this rather unusual purchase, then install the rubber with the best braking characteristics on the rear axle.
Old 07-15-2020, 02:23 PM   #6
RedRide
RedRide's Avatar
I believe that is correct.
In e case of a blow out at higher speeds in the front, you can usually recover without a serious incident. .
However, if a rear blows out, at higher speeds, it can potentially be quite dangerous .
DF210 Front NF210 rear? gsf1200m Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-13-2010 12:15 PM
F/S: Front and rear tow hook. Mister Z Items for Sale by private party 5 05-04-2010 01:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
