Old 08-04-2019, 02:57 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
cranking amps
Maybe someone here has measured the starting amps on the 1.5 engines with one of those amp clamp tools. I want to know just what it draws. I have a start module that works with a battery and it dumps about 220 amps out on start and then a small battery can supply about 200 amps also if needed.....The module might be modified to reduce that amount with an appropriate resisitor...but I want to know what the numbers are
before I use it.. I would guess the 1.5 uses about 150 amps during the summer and maybe 200 in winter,,,??
what do you know???
yaris9876 is offline   Reply With Quote
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 06:43 PM
Constant cranking attrapereves General Yaris / Vitz Discussion 1 09-21-2015 07:55 PM
unauthorized amps patm In Car Entertainment + Electronics (audio / video / alarm) 12 04-03-2012 02:28 AM
Two amps one fuse? And hu install? FuuFuu In Car Entertainment + Electronics (audio / video / alarm) 4 12-24-2011 12:33 PM
Slow cranking on an 02 1.0 vvti Yaris Duberry UK 0 11-01-2010 10:20 AM
