Old 09-21-2015, 05:46 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Constant cranking
This has happened twice recently. Once when I was leaving work and once when my wife was practicing driving and was trying to restart the car after stalling.
I push in the clutch pedal, have the car in neutral, then turn the key to start the car. I keep getting cranking, but the car never starts. If I turn the key off, then attempt to start again, it fires up fine.
I thought maybe the transponder system for the keys was going bad, or the cutoff switch in the clutch. But if that were true, I don't think I'd get cranking at all.
Right now it's not a big concern as it's only happened twice, but if it starts occurring more often, I really need to look into the cause.
Any help?
attrapereves is offline   Reply With Quote
Old 09-21-2015, 06:55 PM   #2
The transponder key not being recognized will allow cranking without firing, so it could be that. To verify, note if the blinking light on the dash goes off when insert the key in the ignition. If it continues to flash with the key inserted, then it is your issue.
Engine "surge" during constant speed John Lenin DIY / Maintenance / Service 11 08-13-2015 05:04 AM
Need constant power to the lighter SARU311 DIY / Maintenance / Service 2 02-06-2012 11:19 PM
engine cranking wafic DIY / Maintenance / Service 4 11-05-2010 01:00 PM
Slow cranking on an 02 1.0 vvti Yaris Duberry UK 0 11-01-2010 09:20 AM
Slow Cranking - Battery? IGGGY General Yaris / Vitz Discussion 15 08-08-2009 11:50 AM
