Old 02-06-2012, 12:26 PM   #1
SARU311
Drives: 2008 Yaris HB
Need constant power to the lighter
Is there a way to rewire the light so it has constant power? Sometimes I need to charge my phone when it's parked and the engine or ignition isn't on.
SARU311 is offline   Reply With Quote
Old 02-06-2012, 08:42 PM   #2
2005rs
Drives: 2005 Echo Rs
Sure. You need to find a spot on your fuse panel that's live when the ignition off. One way to 'cheat' is to shove a wire into the fuse slot and then push the fuse in to hold it in place. I have seen a fuse with a wire attached for feeding a circuit at the auto parts store. Just pick a non-essential circuit so that your charger can't take out your signal lights.
2005rs is offline   Reply With Quote
Old 02-06-2012, 11:19 PM   #3
Revsson
You might want to check with CTScott, as he is the electrical guru for the Yaris.
However, also check out a posting he made recently:
http://www.yarisworld.com/forums/sho...17&postcount=2
It has a link to his remote start DIY, and I believe it shows a constant 12V power
on the fuse block as mentioned by 2005rs above.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
cigarette lighter assmebly no power? csheller In Car Entertainment + Electronics (audio / video / alarm) 6 09-23-2007 07:18 PM
Constant power, always on, sidemarker lights w/ switch... reznunt DIY / Maintenance / Service 17 07-15-2007 11:59 AM
