Old 11-17-2019, 09:36 AM   #1
Kaanktm
Drives: Yaris 1.4 D-4D 2006
Shaking at 95-110 km/h
Hi to all, i have 2006 xp90 D4D manual transmission yaris. It is shaking when you hit the gas at 90 km/h to 120 km/h does it in 3rd, 4th or 5th gear. It goes off when you press the clutch. But the shaking is kind of circular motion like left to right.
What can be the cause any opinions? If you go slow on the gas it is ok but when you want to accelerate faster is starts to shake.
Thanks in advance.
Kaanktm is offline   Reply With Quote
Old 11-18-2019, 04:50 PM   #2
Kaanktm
Hi, guess no one is visiting this part as no answers had came yet. Is it possible to move thread to service/DIY section?
Old 11-18-2019, 06:46 PM   #3
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Honestly it could be anything. My best advice would be to jack the car up, grab the wheels and give them a shake. Have a buddy look for movement in the ball joints, tierod, and control arm bushings
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 11-25-2019, 05:46 AM   #4
rayfloyd170
Drives: Yaris 2016 1.3 Manual
did you also check the motor mounts?
rayfloyd170 is offline   Reply With Quote
Humming noise above 50 km/h. Bearing, CV joint...? jansen.fan DIY / Maintenance / Service 9 07-28-2017 07:07 PM
New Rims + tyres... car is shaking up and down... HELP G-Ammo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 08-30-2014 05:56 PM
07 shaking theb DIY / Maintenance / Service 2 04-19-2013 05:57 PM
Differential bearings worn out - car shaking Unicron DIY / Maintenance / Service 7 06-13-2012 01:07 AM
car shaking after servicing Canadian Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 11-25-2008 05:40 PM
