Old 05-13-2012, 07:42 PM   #1
Unicron
Unicron's Avatar
Drives: Bayou Blue HB 07
Differential bearings worn out - car shaking
At around 36 km/hour, the whole car starts shaking. I have rotated the tires and it made no difference, so the vibration is definitely from the transmission/drive shafts. Today I looked underneath the car to look at the transmission and I could move the (driver side) cv joint around a bit probably 3/16" of an inch of free play, and there is a little oil leaking from the transmission there. I think the differential bearings are worn out allowing the drive shaft to wobble at certain speeds - causing the shaking.
Has anyone had this problem before? Its 2007 with 120, 000 km 2dr HB.
Does anyone know how much it would cost to fix this?
Unicron is offline   Reply With Quote
Old 05-13-2012, 08:15 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yikes. I've torn down a few of these transmissions, and it's no walk in the park. They were also dismounted, and I haven't put them back together, but it's not going to be a small repair bill. It may just be cheaper to get a rebuilt one and pay for the replacement labor. I'm guessing no less than 8-10 hours of labor if you want it pulled and repaired.
Old 05-14-2012, 12:16 PM   #3
auxmike
auxmike's Avatar
Is it the automatic?
Old 05-16-2012, 11:08 PM   #4
Unicron
Unicron's Avatar
it's a 5 spd manual
Old 05-16-2012, 11:28 PM   #5
Unicron
Unicron's Avatar
8 to 10 hours at $60 to $70 / hour, that's like $700 plus parts and tax - probably $1000 all in that. I think the warranty would have cost that much! and I doubt it would even cover labour. Still a little disappointed the Yaris hasn't exactly been problem free since I got it. I am going to have to get a mechanic to look at it.
When you took apart those transmissions did they have worn out differential bearings?
Old 05-17-2012, 12:30 AM   #6
CoryM
Drives: 2009 5-door, 5-speed
It sure sounds possible that this is your problem. When you say 3/16" of play you mean vertical play at the furthest inboard part of the joint? Vertical being the key word there. If it is just sort of rocking up on an angle it's probably normal. If it is going up evenly, probably diff bearings. Typically there is a major oil leak at the axle seal though.
If it is diff bearings, often your best bet is to replace with a used trans in good shape rather than rebuild. Especially on a common car like a Yaris. I'd guess cost of trans alone ~$300-500. Not sure of labour.
That being said, inner CV joints can cause the same feeling. Vibration on accell around 30-5kph. Btw, if your vehicle is lowered it is harder on your inner joints. As always, pretty hard to diagnose via the internet. Best bet is to have a shop look at it.
Good luck.
Old 05-17-2012, 07:53 AM   #7
I have an extra transmission for sale with 20,000km on it if you're interested...
Old 06-13-2012, 02:07 AM   #8
amanda07
Drives: 07~LiFtBaCk/74~scout/BMW-3
....around 36 km/hour, the whole car starts shaking. I have rotated the tires and it made no difference, so the vibration is definitely from the transmission/drive shafts....
It's not the differential bearings IMHO (at least it wasnt on mine) Same exact thing happened to me only it did it at speed AND upon braking.. It was bearings, but in the wheels. ($48 each / US-dollars)
I have the EXACT same car.. even color-- hmmm
I did my brakes, balanced wheels, new tires.. and finally took it in to ask a proffesional at the dealer. As soon as the car was off the ground on a jack, the wheel was visibly 'loose' and could be wobbles by hand. worse on the right side for me. LUCKILY I had purchased a huge 100k mile warranty knowing tend to drive like a d!ck
If I remember right (over a year ago..) ill dig up the paperwork, but i think it should have costed $400 parts and mostly labor
Last edited by amanda07; 06-15-2012 at 06:26 AM. Reason: just wanted to add something..
amanda07 is offline   Reply With Quote
bearing, differential, front, shaking, vibration
What Car Mechanics Don't Want You to Know!! daddz07 DIY / Maintenance / Service 16 04-17-2011 11:10 PM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 10:03 AM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 03:14 AM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 11:58 PM
