Old 09-23-2020, 02:21 AM   #1
ae101
Drives: NCP91L
Lower Control arm bolt keeps spinning
Tried to remove the lower control arm bolt, (rear, vertically mounted, notorious with rust and breaking). Luckily I managed to loosen it with a breaker bar without breaking the head of the bolt but when I'm loosening it with a ratchet, it just keeps on spinning. Any tips on how to remove this? I don't have an impact gun. I don't know why it just keeps on spinning. I tried to remove the carpet but there's no access there or whatsoever.
ae101 is offline   Reply With Quote
Old 09-23-2020, 08:00 AM   #2
tmontague
tmontague's Avatar
Unfortunately chances are the captured (welded) nut inside the sub frame has broke loose and is spinning freely. You may have to either drop the subframe or cut part of the subframe to get vice grips on it and stop it from spinning.
This is where impact wrenches are a huge bonus.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
lower rear shock bolt size? Pinchlite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 08-11-2018 12:47 PM
Carbing lower arm bar Jason@SportsCar Items for Sale by private party 2 01-03-2010 01:03 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
