![]() ![]() Drives: '10 Yaris 3 door HB Join Date: Jan 2010
Headlight Bulb & Rubber Cover.
Hi,
I needed to replace my headlight bulb. Before doing so, I watched a handful of YouTube videos to familiarize myself with the process. I tackled the passenger side headlight bulb today. I unplugged the connector very easily. The rubber cover, however, was really difficult. I pulled and pulled, it wouldn't budge nor come off as easily as in the videos. I moved on, to the metal tabs. Minutes later, I managed to press the tabs to release the bulb. I find out that the bulb and the rubber cover are together, inseparable. It's like the bulb and rubber cover was one. I replaced the bulb temporarily with a cheap LED. I will get a Halogen one eventually but how am I supposed to install the new one without a rubber cover? Common sense tells me to go to the auto-parts store and order the rubber cover with the bulbs. My question to the forum is: Is that normal for the Rubber and bulb to be as one? There was no way I was able to get the rubber off the bulb at all.
Aa |
Cancel the above post. I watched this video, and I just have to pry the rubber cover off.
https://youtu.be/uBYUh-ys92Q?t=302
Aa |
| Tags |
| 9003, headlights, rubber cover |
| diy HID projector w/ halo headlight install | tmontague | DIY / Maintenance / Service | 17 | 02-04-2016 11:34 AM |
| Where can I order a Headlight Bulb Rubber Boot online? | JAM | DIY / Maintenance / Service | 2 | 12-08-2011 06:48 PM |
| How do you remove rubber headlight bulb cover? | detroiter | General Yaris / Vitz Discussion | 2 | 01-18-2010 01:25 PM |
