Old 01-16-2010, 12:24 AM   #1
detroiter
detroiter's Avatar
How do you remove rubber headlight bulb cover?
My drivers side light went out and so tonight I picked up some nice Phillips xenon style lights. I went to install it in the drivers side and boy was it a tight fit! Worse off once pulling off the plug, it had a ton of white lithium grease on it. Then I reached the rubber sleeve. I've been able to slide off the circular housing part but I can't get it to come all the way off. I don't want to pull too hard because I don't want to rip it or anything. Can someone give me some hints here?
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How to remove headlight bulb with chubby hand? D: jmew0ng DIY / Maintenance / Service 2 02-22-2007 11:40 AM
