Old 03-01-2022, 12:37 AM   #1
Mksifa
Drives: Toyota yaris 08 5dr
Speedometer not working
Toyota vitz RS 08 manual trans, speedometer and odometer are not working, I also have an abs and brake warning light otherwise the car drives perfect. I checked it doesn't have a speed sensor on the transmission. anyone with an idea of how to fix this????
Mksifa is offline   Reply With Quote
Old 03-01-2022, 05:53 AM   #2
stidnam
Drives: Starlet
Depending on model, speed is read off the ABS sensors. I'd say there's something wrong with your ABS sensor(s) or ABS computer/actuator unit. Best way to narrow down the problem is to pull the codes via an OBDII reader to see if you can determine what's causing the error
stidnam is offline   Reply With Quote
Speedometer not working - Funcargo / yaris verso St3 DIY / Maintenance / Service 0 12-08-2020 06:29 AM
2015 Yaris Tail Lights Not Working TBowman Third Gen Yaris General Discussion 1 11-20-2016 08:44 AM
Inaccurate analog speedometer JudgeM DIY / Maintenance / Service 2 12-23-2014 05:00 PM
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 11:42 AM
