Old 09-08-2014, 06:19 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Lightbulb Inaccurate analog speedometer
Hi all.
I think many of you know that the speedometer readings in some Yaris are not accurate. I suspected this and confirmed with GPS.
I found that a speedo reading of 100kmh had actual speed of 90kmh.
I was playing around with Techstream and I ran the instrument cluster diagnostic. I found that the speedometer was infact inaccurate and even the tachometer !.
Please see these videos I made. In the second video I test the digital meter which IS accurate.
Techstream speedometer test on analog meter:
https://www.youtube.com/watch?v=5LLENLt-is4
Techstream speedometer test on digital meter:
https://www.youtube.com/watch?v=yFrP4yERDzY
I think its quite interesting.
Anyone else tried this out ?
Is there anyway to 'calibrate' the speedometer?
JudgeM is offline   Reply With Quote
Old 09-08-2014, 08:10 AM   #2
The only way I have found to calibrate them is to digitally modify the signal between the transmission and the cluster. I have only had to calibrate due to tire size differences (and only correctly 2-3 MPH at 60 MPH).
I have never seen one that far off though. I would almost suspect that the stepper motors that drives the needles are damaged from someone removing and re-installing the needle with too much force.
Old 12-23-2014, 05:00 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
This was posted in the wrong section, moved it. Please remember to post your threads in the correct section.
speedometer
speedometer probs. rajjii Off-topic / Other Cars / Everything else Discussions 2 09-29-2013 10:56 AM
Tacho , Speedometer with fix on my car selimesen007 DIY / Maintenance / Service 0 07-11-2013 05:20 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 09:00 PM
DEBATE: Analog vs Digital - Class D vs Old School Amps _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 64 06-09-2012 01:34 AM
