Old 12-12-2022, 06:53 AM   #1
Compeer
Drives: NCP90 TRD Yaris Manual
1nz-fe larger oil filter
Ryco Z158 fits on 1nz-fe and is same price as the standard z386 but has a taller can with a much larger internal filter cartidge. Went with castrol 5w30 full synthetic magnatec this time, black friday special!
Anyway thought I would list all the Ryco filters for the ncp90-ncp131 1nz-fe
Oil: Z158
In tank fuel filter assembly (not cheap): Z791
Air filter: A1559
Cabin Filter: RCA164p
Use Toyota, Ryco or Wix filters too guys for 14 years while I was in parts we cut open all the different brands oil filters and put them on display in our shop, because of this we sold a lot more Ryco and Wix filters. Fram filters for example had a cardboard capped filter canister inside instead of a steel one and a pressed bent sheet spring instead of a precision wound spring and were always rusty inside brand new, rust on the "filtered" side going into your bearings.
Compeer is offline   Reply With Quote
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 05:25 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 10:28 PM
Longer Life Oil Filter? Yar Is Word DIY / Maintenance / Service 14 07-19-2010 07:35 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 03:00 PM
