Old 12-13-2022, 10:05 AM   #5
bronsin
bronsin's Avatar
Originally Posted by remcafee View Post
bronsin, i hate to tell you friend, but modern engines are not a 1974 vw bus, tolenerances and machined internal engine parts are far more tight and oil holes are very small, fram filters are probably going to be ok for most vehicles, on the off chance you get some rust or a piece of cardboard fray (ive seen before) stuck inside your oiling system, the $5 you saved on the oil filter doesnt make sense when you have to buy a $250 vvti solenoid because your crappy oil filter flung debris inside it blocking an oil passage.
Then…. How do you explain why my wife’s 2005 Camry has 200,000 miles on it after using Fram filters half the time? Or are you saying a 2005 Camry‘s engine is not modern?
And my wife’s Camry doesn’t have a whole lot of highway miles on it. Most of it is back-and-forth to work. And it’s 18 years old. And it’s never had synthetic oil. And those tiny holes never had a problem with lots of 10W-30 and even 10 W 40 oil.
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 09:28 PM
Longer Life Oil Filter? Yar Is Word DIY / Maintenance / Service 14 07-19-2010 06:35 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 02:00 PM
