![]() ![]() Drives: 1983 carina 2NZ-FTE Join Date: Dec 2020
TA60 carina with 2NZ-FE from yaris + turbox2
in 2013 i fitted 2NZ to my winter beater with itb setup from honda cbr.
It made 100whp. https://photos.app.goo.gl/oRh8S1gEZ1bndndQ9 2014 summer install turbo, stock internals abou 150whp and made hole in block. Next engine i made fith cp 1NZ na pistons(in 2NZ they give lowwer compression ratio) and autoverdi custom rods. Also add piston cooling jets https://photos.app.goo.gl/y5jjK2MPzysVcKYy5 https://photos.app.goo.gl/6CRnX6Er83hncWzF8 little mods every year, and last summer finally get 260whp on dyno. Turbo starting to get little too small and boost doping in hi rpm, so in autumn i made new turbo system. https://photos.app.goo.gl/1m7NYyNSF6sriuv47 calculated on injector pw engine power was about 360hp It last about week and this happed https://photos.app.goo.gl/Xq1V3ysEU1uT5Qgq7 |
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
Can you share more info on that itb setup?
Also what are you using for management
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
https://photos.app.goo.gl/FduBGCLGzJ3tkcLj8
https://photos.app.goo.gl/4v1uMGkzedLgTAFFA i just use prius intake gasket as template aluminium is easy material even hand tools. weld everything, almoust straight pipes. First i use megasquirt1 lots of self made mods both yaris and cbr injectors was in use. Later made new intake with single throttle and same time go to migrosquirtmodule with some mods. using vvt only on off mode, mechanical limiter in actuator to limit max advance. |
Wow! Very impressive.
#5 | |
i use mifrosquirt module. reason to failure is 2bar boost + 10:1 compression ration + previous litle damages to engine. couple light cratches on cylinder wall causes litle leak and that causes heat to piston. "New" block is ready and waiting pistons. this time lot lower compression ratio.
Haha, that is a lot of boost! Can you tell me more about the Mifrosquirt? I've heard of Megasquirt before. I have the AEM F/IC and don't like it. I can't control partial throttle partial boost fueling in closed loop well enough.
migrosquirt is based ms2 less options but smaller, migrosquirt module is migrosquirt without casing. only thing wrong is that it can't control vvt-i in closedloop. I use vvt-i only on/off mode and made mechanical limit inside vvt-i actuator.
Thanks for the explanation!
![]() Drives: n/a Join Date: Apr 2020
very interested in your rwd conversion - t50 gearbox or w5*? how did you modify the bellhousing or do an adaptor plate?
thanks |
w58 i weld new mounting plate to bellhousing. new injectors and fuelpump is coming 957cc injectors max out and fuelpump can't keep 4bar basepressure in high boost.
2.4bar is now max boost. Stock yaris clutch pressureplate with cerametallick disk can hold all torque engine is making. |
#14 |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
Subscribed!!!
#15 |
#16 |
1/4 mile testing in airfield street tires. speeds is kph.
#17 |
Ne personal best at 1/8mile
#18 |
hot damn thats fast, especialy for a tiny motor, i loved 8th mile for a time with my 67 barracuda
to be making that kind of power and actualy working it..out of a 1300 is incredibly impressive i mean i was thrilled to get 400hp NA out of a hybrid 20/22r in a gen1 celica but to be making almost that same power out of 700CC less is astounding |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-07-2012 12:37 AM |
| Vacationed in Italy - Brought home a D4D diesel Yaris | CTScott | Photo-Video-Media Gallery | 19 | 07-26-2012 04:13 AM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
