![]() Drives: Toyota Vios Yaris Join Date: Mar 2016
Hello,
Anybody can helpme to understand the wiring of this model?? This is a drive by wire 1nz fe, also know as Third generation Vios. http://s2.paultan.org/image/2015/01/...0717440659.jpg My guest is pin 40 of conector A21 as always. Best Regards Javier |
This car is being sell in Latino America as a Toyota Yaris
From what I have read about the 3rd gen Vios cruise control is not even an option, which likely means that the ECM is not programmed for it.
You can check the steering column connector for presence of the wires for it and if they are present, then perhaps it does.
I know for fact that is not just de cruise control switch because I try the just switch and didn`t work. I did not check the spiral wiring to the DL3 conector and didn`t check the wiring from the DL3 conector to the ECU (pin 40).
If were a programing problem... Is there any solution? Or I need to go with an aftermarket cruise control ?? Best Regards Javier |
#5 | |
I just have the model, later I´m gonna try to remove the "bag" to see the ecu.
I still can`t figure out how to remove it |
That's the AC ECU.
CTScott,
Here is the Engine Control unit, is not the shape that i did hope. Best regards Javier |
Anyboby any help ???
As I said above, cruise control is not available on the 3rd gen Vios.
Ok, thanks ...
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
surprised to see your ecm is made in the philippines. probably in the Sta Rosa Laguna plant. well i wouldnt be surprised one bit that Scott is right, for one, he is right 99% of the time, and two, Vioses in the Philippines don't have cruise control even as an option.
Hello,
I see that cruise control is not even an optional in Vios/Yaris, but the steering wheel came with a cover to remove for a cruise control switch, that`s why I belived that is was posible conecting the ecm in the correct pin... If is not posibile just conecting the switch to ecm, Is another solution ?? A toyota module ??? An after market cruise control ?? Another ecm ?? Thank you both for your answers... by the way this yaris is made in Thailand. Best Regards Javier |
#14 | |
#15 | ||
Cool, some of my Yaris parts are made in Thailand actually, i've seen Made in Japan too in some them (IIRC). Quote:
#16 |
Hello,
This is my toyota steering wheel, I`m still hoping solution, I know that this ECM is not the one that have cruise control in pin 40 of conector 21, but the ECM of 4 row and 4 conector could have cruise control programing in pin 21 of the conector with 31 pins as in toyota hilux ... Any comments ?? Best regards Javier |
#17 |
I did try with 21 pin and 30 pin ... no luck yet.
#18 |
You can try every pin on the ECM and still will have no luck. I am not sure what part of your ECM does not support cruise control you do not understand. Your only option will be an aftermarket cruise control kit.
| Yaris cruise control doesn't work | pootango | DIY / Maintenance / Service | 10 | 07-02-2012 05:11 PM |
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 03:14 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 07:29 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
