Old 07-01-2012, 03:06 AM   #1
pootango
Drives: 2010 yaris
Yaris cruise control doesn't work
Hi There
I have a 2010 Yaris Hatchback with a standard transmission. I just purchased the 84632-08021 cruise control switch, wire and installed it as per instructions.
http://web.newsguy.com/mcclure/Yaris...2020110315.pdf
I turn on the cruise control, the light comes on my dashboard saying cruise is on, but it does not work. i cannot set the cruise speed. I have reviewed the installation instructions and everywhere seems to say you plug it in and it works... but mine doesn't. Has anyone come across this before?
Thanks so much.
pootango is offline   Reply With Quote
Old 07-01-2012, 07:37 AM   #2
Originally Posted by pootango View Post
Hi There
Thanks so much.
Did you install the cruise control clutch switch, which per my DIY, is required for a manual transmission car?
Old 07-01-2012, 10:21 PM   #3
pootango
Drives: 2010 yaris
no i have not yet but will that make a difference? i thought it said it would work without it.
Old 07-01-2012, 10:28 PM   #4
It will make all the difference. The switch not being there is the same as the clutch pedal being touched, which cancels cruise (like stepping on the brake).
Old 07-01-2012, 10:31 PM   #5
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
With a manual, the switch is there to disengage the cruise control if you depress the clutch.
In the table on page 1 of CTScott's instructions it says that that the wiring isn't necessary, but the switch is still needed. Maybe that is the point of confusion?
Edit: CTScott must be a faster typist than me!
Old 07-01-2012, 11:33 PM   #6
pootango
Drives: 2010 yaris
yeah just installed the clutch switch and now it works perfectly, thanks so much. Got any suggestions for any more mods ? i was thinking of a cold air intake
Old 07-01-2012, 11:40 PM   #7
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
I just did the lightweight crank pulley yesterday, and I think it's my favorite mod so far! Good tradeoff between time and money spent and results!
Here's a decent thread where I threw some ideas around for what good mods to do on a reasonable budget. There are a couple more like this one as well, search around the site and you're bound to find something that sparks your interests.
Old 07-02-2012, 12:02 AM   #8
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
pootango, another good thread to read: The Yaris Performance Primer
Old 07-02-2012, 03:01 PM   #9
pootango
Drives: 2010 yaris
what does the light weight pulley do for the car ? just help it rev faster?
Old 07-02-2012, 03:25 PM   #10
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Lighter weight, less parasitic power loss, easier to spin due to lower mass rotation...basically, more power is freed up.
Old 07-02-2012, 05:11 PM   #11
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Best description I've ever been given:
“Anything that reduces rotational inertia frees up power. That includes the crank pulley, the flywheel, and your wheels/tires.
“Take a CD in with your fingers around the edge, and spin it back and forth. Now imagine it’s made of steel and much heavier. Harder to spin. Same concept.”
cruise control
Does DFCO still work when using cruise control? rtom Fuel Economy Forum 10 01-20-2010 01:26 AM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
