Old 06-15-2007, 02:59 AM   #1
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
mono amps
hey guys, im a novice in car audio, i know what i kinda want but not sure on the power ratings. ok so im looking at subs right now, i want something good but not too over powering. im thinking gettin one solid 12" 1600w rms sub. 4 ohm dvc. now what will it take to power it up 1000w mono or i have to get the 2000w mono. is this sub too much? or should i just get 2 12" svc 4ohm 600w rms and what would power that up. if you must know the subs they are from crystal mobile sound. either 2 comp 12's or 1 comp x212
http://www.crystalmobilesound.com/subwoofers.htm
any ideas would be welcome.
this will basically determine the setup of my car, already have the head unit in mind, and will be going with ppi amps, depending what i need to power up these babies. but one mono and 1 4 channel ppi amp and a set of crystal scc6 or q series mbquart components
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 06-15-2007, 06:40 AM   #2
punch
punch's Avatar
Go with 10"
punch is offline   Reply With Quote
Old 06-15-2007, 05:16 PM   #3
ponieswhee
Drives: Black 07 Liftback
1600W RMS in a Yaris? :P I thought you didn't want something overpowering... Just remember that if you keep your stock head unit, your fullrange speakers are probably only getting about 10W each. I'm running one 10" with 300W RMS going to it and it works just fine for me. Previously I was running 3 10" subs with 400 watts total and it was way too much.
The last time I heard anything close to 1600 Watts was in my buddy's old Camaro, which had 4 Fosgate Power 10's and a PPI Art Series 1200 Watt beast. First time he tested the system a huge chunk of rusty metal got blown off the bottom of his car.
ponieswhee is offline   Reply With Quote
Old 06-15-2007, 05:28 PM   #4
ponieswhee
Nice choice on gear though, that Crystal stuff is sweet. $799 for one sub, though, damn! A lot of high end manufacturers underrate their equipment and I suspect Crystal would be one of them, so I wouldn't be surprised if that single 12" could handle 2000 Watts. If I were you I would go with the 1000W amp bridged mono into 2ohms and run it to a single DVC 12". You get more bang for the buck if you utilize your amp to it's full potential. For example you could get a 500W mono amp and bridge it to 2 ohms to get 1000W mono out of it, which I think would be more than enough for a car the size of a Yaris. This beats the hell out of getting an amp that puts out 500W per channel stereo 4 ohms and running two 4 ohm subs, because it'll cost half as much.
Old 06-16-2007, 03:25 AM   #5
sdmf
sdmf's Avatar
so your saying just go with the comp x212 dvc? i found the comp x212 for $344 from an online retailer, im just gonna wrap it n a q logic box. thanks alot for the input, will take pics when this project occurs, will be changing the head unit to clarion usb3573 or just get the other one without the screen. probably need to dynamat everything though
Old 06-21-2007, 03:15 AM   #6
nauc
nauc's Avatar
Drives: NA
all depends on how much room you want to give up, how much money you want to spend, what you want... sq or spl etc etc
a good 12" sealed in 1 cubic foot with 500 watts will be more than enough for a sound quality (sq) setup
for more output (spl), 1 12" ported in around 2.5 cubes with around 1k might knock your center mirror off
some killer bang for the buck subs
www.ficaraudio.com
www.tcsounds.com
id think about getting a sub that can be wired into a lower impedance like 1 ohm since most amps put out more power the lower the impedance so you'll get more power for your dollar
wiring info...http://mobile.jlaudio.com/support_pages.php?page_id=141
Red Top, 9833, 180CS, 12" HC in 3.6@29, a1200
nauc is offline   Reply With Quote
Old 06-21-2007, 10:04 AM   #7
armature
Drives: yaris lb
i'm not even sure that the alternator in the yaris will be able to support the current required for amps rated over 1000W.
armature is offline   Reply With Quote
Old 06-25-2007, 12:52 AM   #8
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
Hey SDMF - go Alpine PDX (either 1.600 or 1.1000 mono) for the sub. Great amps.
SeriousBlack is offline   Reply With Quote
Old 06-25-2007, 01:03 AM   #9
sdmf
sdmf's Avatar
sorry not an alpine fan, not a kicker fan, not a rockford fan, too commercialized for me, i like precision power inc. for amps.
Old 06-25-2007, 01:30 AM   #10
good point about the alternator, but you could send that out to get it beefed up if necessary.
Mounted My New Alpine Amps drell42 In Car Entertainment + Electronics (audio / video / alarm) 35 07-07-2007 11:31 AM
To those with amps in your trunk/rear... vodkalush In Car Entertainment + Electronics (audio / video / alarm) 9 10-03-2006 06:34 AM
Hatch/Liftback Owners with AMPs - Where did you connect the ground? bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 10 09-28-2006 02:21 PM
Amps, Subs, Bandpass... Yar In Car Entertainment + Electronics (audio / video / alarm) 26 09-08-2006 01:20 AM
