Old 09-27-2006, 06:04 AM   #1
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
Hatch/Liftback Owners with AMPs - Where did you connect the ground?
I would like to know where the best areas are for the ground connection for an amplifier in the rear area of the Hatchback/Liftback, particularly in the spare tire well and trunk area.
Can anyone offer some help before I run off to RadioShack for a voltmeter?
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 09-27-2006, 12:34 PM   #2
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
Right Under the backseat. One of the bolts that hold the seat and set up down should work great.
nick1983 is offline   Reply With Quote
Old 09-27-2006, 05:34 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
Thanks nick, but I'm not sure if I can locate those bolts.
Do I need to remove the seat bottom (mine's a hatchback) to expose those bolts?
Old 09-27-2006, 05:36 PM   #4
bigsky2
Cousin Vitz
bigsky2's Avatar
I've attached two photos here for potential grounding points:
Spare Tire area - 6 Points
Seat Belt lower bolt - 2 Points (left/right)
What do you think?
PS - Thank you Idjit for taking these pictures.
Old 09-27-2006, 06:23 PM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
What do you think?
it looks like the rear seat is lifted UP?
how did you do that?
How do you remove the rear seat from the frame like that last pic
Old 09-27-2006, 06:43 PM   #6
bigsky2
Cousin Vitz
bigsky2's Avatar
The rear seat is not lifted up in the 2nd picture.
According to Idjit, the rear seat bottom was removed by disengaging two clips on the bottom of it that held it to the frame.
Old 09-27-2006, 08:25 PM   #7
Wayside
Wayside's Avatar
Drives: 07 yaris 5spd sdn
bigsky2,
Any factory bolt will do the trick; just make sure that the ring terminal is touching the chassis metal. If necessary, don't be afraid to scrape a little paint off.
Wayside is offline   Reply With Quote
Old 09-27-2006, 09:47 PM   #8
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
I agree
grind, scrape or sand away any paint between the ground and the metal chasis. I would also add a dab of dielectric grease to keep it corrosion/rust free.
Bigsky2
thanks I did not realize that.
The RS has a different set up with the flat folding seats I guess.
Old 09-28-2006, 01:52 PM   #9
nick1983
nick1983's Avatar
What do you think?
Any one of those bolts would be great for grounding. If you want better results you can ground to 2-3 of the bolts. Remember the threaded bolts and holes and not painted. So grounding shouldn't be an issue
Old 09-28-2006, 02:19 PM   #10
bigsky2
Cousin Vitz
bigsky2's Avatar
Originally Posted by 07WYarisRS
I agree
Bigsky2
The RS has 60/40 split fold down seats. I guess the LE/CE only has the flat fold down of the entire seat ... ?
Yes, I will definitely grind and sand down the area I'm going to ground to.
Thanks for the advice.
Old 09-28-2006, 02:21 PM   #11
bigsky2
Cousin Vitz
bigsky2's Avatar
I think I'm going to use one of the four lower bolts pictured in the first picture, which hold the plastic trim down. I took out the bolts yesterday and I saw that it was touching the chassis. Pretty good!
I'm only going to select one ground point, as I'm grounding everything to a single point to prevent any new electrical paths to form, which could distort.
Just needs some sanding and it should be good to go.
