Old 07-25-2007, 07:20 PM   #1
engine dampener?
Sorry if this was covered, but anyone making an engine torque dampener for the Yaris? Or, do we know for sure an xB or xA one will fit?
thanks
Old 07-25-2007, 10:19 PM   #2
ChinoCharles
Drives: LB
I couldn't imagine a Scion damper fitting the Yaris. I would like to see one too, though. Everyone pester DME until they make one.
http://www.dme-power.com
Old 07-26-2007, 07:16 AM   #3
Jerkratt
Jerkratt's Avatar
umm i think c-one makes one
Here
"It hurts more when its wet"
Old 07-26-2007, 01:34 PM   #4
"currently in production" -- means it's not made yet, I think...
That is sweet, I will want one.
Old 07-26-2007, 02:24 PM   #5
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
will it fit? could you do a DIY guide with it? i would greatly appreciate it.
Old 07-26-2007, 02:33 PM   #6
yeah, i'd like to see that too, along with what brand it is and where you got it?
.... pleeeeaaaaase?
Old 07-26-2007, 07:42 PM   #7
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
Sorry for this noob question but what is an engine damper used for?
eijikikimaru is offline   Reply With Quote
Old 07-26-2007, 08:33 PM   #8
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
i am not familar with dampers on engines, but it looks like a poor mans motor mount without the harsh ride. looks like a strut mounted to brackets going to the motor and the strut tower brace.
i am guessing it would give firmer shifts without compramising ride like stiff mounts do, someone can correct me on this, cause i am going off of what it looks like...
Old 07-26-2007, 08:36 PM   #9
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Mostly for looks.
A rigid brace will stop the block from twisting with the transmission, thus loosing torque. the block wants to spin with the crank, you don't want that, because the torque used to spin the block would be better used to spin the tires. Having the engine rigidly anchored to a solid part of the chassis keeps it from spinning.
Solid engine mounts are a more efficient means of halting engine movement, but you pay for it in NVH. Solid mounts are a bitch to drive with! Poly mounts are a little better/worse - they aren't nearly as solid as metal, so you get less NVH but on the other hand they still allow the engine to move.
A rigid brace would help a little, but you still have a NVH problem.
The problem with most dampners is that they are dampners, a fluid filled shock absorber. They do nothing to halt engine rotation.
WRBlue is offline   Reply With Quote
Old 07-26-2007, 08:42 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
My LeBaron GTC had one. Perhaps I can retrofit it to the yaris....
Old 07-27-2007, 02:46 AM   #11
whooppee777
NVH?
Old 07-27-2007, 03:10 AM   #12
2006fronty
2006fronty's Avatar
Drives: 2010 Mazda3 iTouring
Noise Vibration Harshness
Old 11-24-2008, 03:23 PM   #13
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
Is there already a engine damper for the 1.8 2ZR-FE ?
I think the engine support is not exactly the same as the 1.5 engine or did I wrong?
andries is offline   Reply With Quote
Old 11-24-2008, 03:40 PM   #14
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Nop
There is no engine damper for the 2ZR. You probably will have to buy a damper and get some custom brackets to mount it.
The Yaris and the Yaris TS share a few of their engine mounts but the upper one on the right side is not one of them. Completely different form one car to the other.
And even if there are no Dampers available, there are some other options that can be used to reduce the Engine movements.
Old 11-24-2008, 03:51 PM   #15
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
good luck on the wait seeing as they were supposed to release a BUNCH of yaris items after last years sema......
Old 11-24-2008, 04:36 PM   #16
kou
Drives: 08 lb
found this product on mcmastercar #8644k11 $29, i am just going to fill the trans mount and the bottom one with it. 2 new mounts and this stuff to fill them will be cheaper than a c-one rollstopper mount alone.
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 09:16 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 02:43 PM
Engine bay prettification project eTiMaGo Cosmetic Modifications (Exterior/Interior) 14 04-23-2007 05:22 PM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 03:03 PM
looking to build engine... joey1320 Performance Modifications 6 04-04-2007 12:06 AM
