Old 05-23-2007, 06:21 AM   #1
Avia
Drives: yaris
engine question... (2ZR-FE and 2ZZ-GE)
the first one is the new yaris TS engine and the second one is the celica TS engine.
both are 1.8, both are vvt-i, both are 16v.
the yaris engine produce 133 bhp, but the celica engine produce 190 bhp.
what do i miss?
Avia is offline   Reply With Quote
Old 05-23-2007, 06:27 AM   #2
VVTL-i and a GE vs FE head
2ZR is economy-oriented, 2ZZ is performance oriented, basically!
Old 05-23-2007, 03:54 PM   #3
bet you can swap the FE head with a GE head..
so you'd have a 2ZR-GE...
and later generation of the 2ZZ only outputs 180 on the celica and 170 on the corolla.. hehe funny shit.
Old 05-23-2007, 11:53 PM   #4
I doubt it'll work properly... the 2ZZ has variable lift, which is controlled by the ECU. If you put that head on a non variable lift engine, the ECU won't know anything about it... Unless you change the ECU as well, but that's certainly another can of worms...
Oh and yeah, there are certain sub-versions of the 2ZZ as mentioned, with different outputs... Standard Toyota spec is 180hp for the Celica, Lotus tweaked their version to 190hp (or 230hp if I am not mistaken with a supercharger in the Exige S), and the Corolla version was de-tuned I think to suit some regulations (as it's not considered a sports car like the Celica, it probably needs to be quieter, I dunno...)
Old 12-23-2010, 05:49 PM   #5
weapon5
Drives: VITZ
the 2ZR-FE is also dual vvti verse the 2zzge which is not but the 2zzge does have lift like you guys mention. doing a ge head is simple you have your fe head and you do a head job bam GE lol :D
weapon5 is offline   Reply With Quote
Old 12-24-2010, 08:16 AM   #6
all 2zzge's put down the same at-wheel horsepower, despite what the brochures say
2zrfe would fit in the yaris MUCH more easily than a 2zzge
