Old 12-29-2008, 08:21 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
Who here has done oil change without a jack???
i mean, the drain plug is so conveniently located near the front bumper, i can just sttick my head in and turn it with my ractchet
Yawesh is offline   Reply With Quote
Old 12-29-2008, 08:42 PM   #2
xpeteyjtx
Drives: 07 BB Yaris
I have never use jacks/ramps to do an oil and filter change on the Yaris.
xpeteyjtx is offline   Reply With Quote
Old 12-29-2008, 09:33 PM   #3
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
wtf
My yaris has stock suspension and I can't even start to get under there.
But hey, if you fit, go for it. I know I would.
DFA is offline   Reply With Quote
Old 12-29-2008, 09:49 PM   #4
xpeteyjtx
Drives: 07 BB Yaris
Originally Posted by DFA View Post
wtf
Well I don't think many people would "fit" under there. I lay down on the ground next to the car (you may be able to get your head under the car) and reach for the drain plug and oil filter.
No dealing with jacks/ramps and it is safer.
Old 12-29-2008, 10:00 PM   #5
Chrsto4
Chrsto4's Avatar
Drives: 2008 Yaris RS 5-dr HB Black
I avoid the jack all together and just use my horn. I tap it gently and the dealership opens the bay door.
Yes......even as I write this I KNOW I'm being a winky stick but...I...just...can't...help myself. Seriously though, kudos to all you DIYs who save a buck and gain a sense of pride. Cheers.
Chrsto4 is offline   Reply With Quote
Old 12-29-2008, 10:03 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
My car is lowerd so cant really fit under there. But i park it on my driveway so its already slightly angled. THen put the jack under the lift point on the passanger side front. Brings the front end enough to fit under there easily.
Old 12-29-2008, 10:04 PM   #7
gid
use homemade wooden ramps . 2" (h) x 12"(w) x 36" long with one end cut at an angle ( to drive up ) and a 2 pieces ( stopper ) of 2"x2"x12" , which 1 is nailed / screwed to each end of ramp to stop car from going over the edge . Make sure it's not split or too many knots for strength . Would think pressure treated be best to endure weight .
Old 12-30-2008, 01:04 PM   #8
gid
homemade ramp ...
go to , http://s49.photobucket.com/albums/f2...0Oil%20Change/ . Click on images for a look . Nice 1st generation XB too . Kin to the YARIS .
Old 12-30-2008, 03:16 PM   #9
gid
or ...
could just use use layer of 2" ( H ) x 10" (or 12") (W) x 36" ( L ) . Be easier for car to climb and oil pan be angled . Better yet , use 1 board of 1 level under 1 or both wheels on drivers side . That way pan be sloped for better drainage . Hope I'm not confusing you to much .
Old 12-29-2008, 10:18 PM   #10
Bullet120
Drives: 2007 Yaris Sedan
I've done an oil change w/o ramps or a jack a couple times and did a filter swap topside with the hood raised. THE reason I bought this car was long term cost of ownership. The ease of working on it is a huge benefit, too.
Bullet120 is offline   Reply With Quote
Old 12-29-2008, 10:22 PM   #11
ChinoCharles
Drives: LB
TRD suspension = I need me some jack stands!
Old 12-29-2008, 10:50 PM   #12
auxmike
auxmike's Avatar
I jack up the driver's side and then go to town.....
Old 12-30-2008, 04:17 AM   #13
GeneW
Drives: 2008 Yaris
Trivial - you get an oil pan no higher than about seven or eight centimeters. You buy a wrench for the bolt (I think it's a 17mm but am not certain) and an oil filter socket.
I routinely do my oil in the street without a lift. One of the reasons I bought this car was for this reason.
Gene
Old 12-30-2008, 06:27 AM   #14
elmo
WFO
elmo's Avatar
Drives: 2008 hb
i use ramps, makes life a lot easier, i ain't no "youngster" so i have learned the easier the better
elmo is offline   Reply With Quote
Old 12-30-2008, 11:12 AM   #15
hop
Drives: 08 Yaris HB manual
I dont use jacks or ramps.. I am 6 foot 200lb and i can get it done.
i can almost do it on my knees and just reach under with a socket wrench.. when the bolt is loose take the wrench out slide the pan under and take the bolt out with your fingers.
hop is offline   Reply With Quote
Old 12-30-2008, 11:29 AM   #16
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
A Fumoto oil sump drain valve makes it a lot simpler.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-30-2008, 11:37 AM   #17
Rich k
Rich k's Avatar
Drives: 07 3dr white Yaris 5spd stock
Send a message via AIM to Rich k
What brand / types of pan to drain the oil into fit under the yaris w/o jacks ramps?
Rich k is offline   Reply With Quote
Old 12-30-2008, 03:17 PM   #18
xpeteyjtx
Drives: 07 BB Yaris
My pan has a maximum height of 4.5". You have to loosen the drain bolt with a wrench, then remove it with your left hand, while using your right hand to maneuver the pan under the bolt.
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
