Old 03-15-2012, 06:33 AM   #1
Rambie2006
Rambie2006's Avatar
Drives: 2005 Yaris P2 S-line
1.5T swap
I am thinking to throw a boosted 1NZ-FE in my 2005 yaris.
But i've heard the turbo is a dealership option.
Since i drive the 1st generation facelift, does the engine has the same hingepoints as before the facelift?
Thanks!
Rambie2006 is offline   Reply With Quote
Old 03-15-2012, 12:59 PM   #2
This should get moved to the Forced Induction forum.
You have a 1.5 now, so it's a swap for a 1.5T? Should be the same mounts, etc.
Old 03-15-2012, 01:21 PM   #3
Rambie2006
Rambie2006's Avatar
I'm running the 1.3, but i want some more horsepowers that's why i want the 1.5T.
Old 03-15-2012, 02:52 PM   #4
You'd have to compare part numbers to see if the motor mounts (2) and the trans mount are the same.
Further, the ECU is probably different, so you'd have to source an ECU to go with the 1.5L motor or manage the new motor with aftermarket + tuning.
Just my guesses, as I've never seen a 1.3 in person.
Old 03-15-2012, 03:18 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i think it would cost you less to just throw an aftermarket turbo on your 1.3. And no, the 1st gen has some differences,the second gen has electronic throttle and a different final gear and a different fifth gear, and a few other changes. I don't know if the dimensions or mountings are different.
Of course, if you just switch everything all at once from a wrecked one that still has everything working and keep it stock it could be cheaper.
Colin Chapman disciple
Old 03-16-2012, 01:31 PM   #6
Rambie2006
Rambie2006's Avatar
@why?: I've been thinking about boosting the 1.3 i have now. But i don't want a turbo just for the BOV, i really want some boost. Since the 1.3 internals arn't ment for such thing, i think that could make a big cost total. That's why i thought it would be cheaper and better to throw a stock 1.5 turbo from the Vitz/Yaris RS turbo..
Old 03-16-2012, 01:39 PM   #7
the 1.5 is identical between turbo/non turbo versions, not really factory-designed for boost either...
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-06-2010 12:25 AM
Looking to swap broadway mirrors YarisSedan California 2 12-18-2009 01:11 PM
09 Meteorite Metallic Front Swap RacerFreakXXX Items for Sale by private party 13 07-24-2009 08:22 AM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 04:32 AM
