Old 04-07-2009, 01:10 PM   #1
Adrenalingirl_K
Drives: yaris
Gauge Cluster Swap, other interior swap questions.
Is it a direct swap to the gauges with the Tach in it? Plug and play so to speak? Is the odo info stored in the gauges or in the ecu?
Also, is the car pre wired for power windows, so all I would have to do is swap all the stuff over? Sounds like a weird question, but i know most manufacturers run the wiring for everything so it's one less part to produce seperately. IE cars without fog lights often times are wired for them, you just need to install the lights themselves, which I am hoping is the case with the window motors.
Same deal with the cruise control, is it wired, just needs the hardware?
Any insight would be appreciated. Some is more curiosity for if I find a good deal, but the tach is a big thing right now as I want to start autocrossing and don't really want to install an aftermarket tach.
Adrenalingirl_K is offline   Reply With Quote
Old 04-07-2009, 01:37 PM   #2
yarstar
Drives: 2008 Absolute Red HB
It's not plug and play. AFAIK, no one on here has been able to do it successfully. I think someone switched out a dash from a Canadian model, but then you have Kms for speed.
I looked at quite a few options, but settled on a small tach on the top of the steering column. I used a GlowShift that nearly matches the dash lighting AND I can still get into my driver side glovebox.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 04-07-2009, 03:31 PM   #3
the ODO is stored in the cluster.
and, do you really need a tach for auto-x ?? I don't think so.
Old 04-09-2009, 03:23 AM   #4
Adrenalingirl_K
Drives: yaris
Yeah, you do, waiting till you hit the rev limiter to shift to second is a poor way to do it and waiting till the car leaves it's power band to wait to down shift is an even worse idea. Hell, I mean, if you just downshifted when it was slow, you would never find a gear low enough.
Old 04-09-2009, 03:32 AM   #5
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i just added and aftermarket tach
FS: Authentic JDM TRD Gauge Cluster Tri Meter Cover R0ME0 Items for Sale by private party 3 03-15-2009 08:13 PM
09 Liftback Speedo Gauge cluster dilemna with picsŪ pariahdecss In Car Entertainment + Electronics (audio / video / alarm) 4 01-28-2009 02:04 PM
Gauge Cluster LED's Kaotic Lazagna Cosmetic Modifications (Exterior/Interior) 11 01-08-2009 12:59 AM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
Canadian gauge cluster work in US Yaris HB? heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 7 08-25-2007 01:20 AM
