Old 01-11-2009, 02:17 PM   #1
dimsum69
Drives: 2009 Toyota Yaris
DRL and HID's?
Hey guys, I'm pretty sure I know the answer to this question, but I wanted to make sure.
I have a canadian model, so my DRL's run my lowbeams, I'm interested in putting HID's into them, since everything down to my bike has them, but will the DRL's interfere with the HID's running properly?
I'd actually prefer to keep the DRL's over getting HID's, so thats why I'm asking, but if anyone has success with running HID's w/o touching the module I'd be a happy dood
tyvm
dimsum69 is offline   Reply With Quote
Old 01-12-2009, 12:44 AM   #2
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
as you mentioned, its one or the other. Lose the DRLs for the glare kit, or keep the DRLs and stick with halogens. Most kits do not come with relay harnesses, and the low power of DRL's do not help with ballast life from the low power.
taKuto is offline   Reply With Quote
Old 01-12-2009, 08:11 AM   #3
pinoypizzaboy
Drives: 08 toyota yaris LB
If u get hids u have to remove drl or its gona flicker. :)
pinoypizzaboy is offline   Reply With Quote
Old 01-12-2009, 10:42 AM   #4
Treyz
~ ambient one ~
Treyz's Avatar
The voltage for the DRL's are lower than when you actually turn them on so as stated above, you will need to disable your DRL's which is pretty simple to access to and do.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 01-12-2009, 12:38 PM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
you can relay it...problem solve..
getting rid of the drl may shut off fog lights if u got one.
Old 01-12-2009, 04:30 PM   #6
Treyz
~ ambient one ~
Treyz's Avatar
I remember Chris07 having a write up on this and how to DIY.
Don't recall a foglight problem. Care to share about the relay =]
AMBIENTLIFESTYLE
Micro Image
- DISABLED DayTime Running Lights How To- 2007 Yaris! - Chris07LB DIY / Maintenance / Service 266 09-04-2017 04:34 AM
Where is my DRL Module......? Help With HID's The Architect DIY / Maintenance / Service 6 05-20-2009 11:21 AM
My Yaris and My Mods rage2 Photo-Video-Media Gallery 44 04-24-2007 05:31 PM
HID's and Daytime Running Lights rage2 Cosmetic Modifications (Exterior/Interior) 17 04-13-2007 03:10 PM
DRL enabled with HIDs... sort of... Galavoxx Cosmetic Modifications (Exterior/Interior) 0 03-28-2007 09:26 PM
