Old 12-30-2008, 03:21 PM   #1
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
Exclamation Where is my DRL Module......? Help With HID's
Ok so I got HIDs in today (as shown below)
theyve got a ground and a power wire.
i put the wires in the headlight harness, the ground went into the slot that it did because the other slot had no effect at all (as illustrated below)
and turned on the lights and the bulb flickers then turns off.
I figure....DRLs need to be removed.
I find the DRL removal official thread and search underneath my steering wheel and all around for a half hour with no luck...
If I dont have a DRL Module for some reason then why are my HID's flickering?
HELP
THIS IS WHERE THE TUTORIAL SHOWS IT BEING
PG TLD22 8V Line Driver
Old 12-30-2008, 04:16 PM   #2
33OH
Drives: '08 Yaris
I'm sure you searched very thoroughly, but the DRL module is hidden REALLY well. It took me a really long time to find it (and an even longer time to pull it out...)
Do you have the convenience/cold weather package?
Old 12-30-2008, 04:57 PM   #3
The Architect
Give Me Resonance
I dont think that I do, to be honest Idk, I think i resolved the HID flickering problem but im still curious as to where the module is at if I even have one.
Old 12-30-2008, 09:31 PM   #4
that picture of the DRL module is of it taken out of its bracket.....i left mine up there and just unplugged the harness for it. i think i can see the wiring for it on the right of your last pic....its really tucked up and to the right....and its a biotch to get unplugged too (esp if you have bigger hands)
youll want that DRL module off before you fry your ballasts...
i also see you didnt buy bi-xenon HID's....looks like youll be w/o high beams...
Old 12-30-2008, 09:34 PM   #5
The Architect
Give Me Resonance
i got them installed and working fine without any flickering or anything, didnt get the drl module out, my headlights are the depo projectors and yes im w/o high beams but theyre so bright it doesnt really matter, i never use highs anyways.
Old 05-19-2009, 06:56 PM   #6
Yaris_PR
Yaris_PR's Avatar
Drives: Red Yaris Hatchback on 18's
Send a message via MSN to Yaris_PR
Hey architect how did you solved your bulb flickering problem??? I didn't find the drl's too.
Yaris_PR is offline   Reply With Quote
Old 05-20-2009, 10:21 AM   #7
http://shop.ebay.ca/?_from=R40&_trks...All-Categories
DRL Questions. AznGouki Cosmetic Modifications (Exterior/Interior) 14 10-28-2008 03:07 PM
DRL disalbled. IllusionX DIY / Maintenance / Service 0 10-22-2008 03:16 PM
DRL enabled with HIDs... sort of... Galavoxx Cosmetic Modifications (Exterior/Interior) 0 03-28-2007 08:26 PM
Using parking light as DRL? GabL DIY / Maintenance / Service 6 11-11-2006 09:31 AM
NO DRL ???? argylesocks DIY / Maintenance / Service 8 08-12-2006 08:24 PM
