Old 01-15-2007, 08:03 PM   #1
dngz
dngz's Avatar
Drives: black yaris sedan
lightweight flywheel from fidanza
Just got an email back that Fidanza has a lightweight flywheel for the 2007 Yaris 1.5 DOHC. The part number is 133151. Just waiting back for pricing and info!
dngz is offline   Reply With Quote
Old 01-16-2007, 07:03 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Had one on my 330 BMW. Made quite the difference.
Old 01-16-2007, 11:07 AM   #3
acrbill
Drives: Polar White Hatch
The Fidanza site says the flywheel weighs 8 lbs.
Here is one on ebay.
http://cgi.ebay.com/ebaymotors/FIDAN...spagenameZWDVW
Doing some searching shows that the stocker weighs 15lbs.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline   Reply With Quote
Old 01-16-2007, 12:21 PM   #4
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
If you do the flywheel, you have to do the clutch. And you have to do a DYI.
I would love to do mine but it's going to have to wait until later in the year.
Galavoxx is offline   Reply With Quote
Old 01-16-2007, 01:47 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
What are the pros and cons of this mod in a small engine like the Yar?
A BMW 330 is not a good reference...
Old 01-16-2007, 02:46 PM   #6
Chris07LB
Chris07LB's Avatar
Wasnt making a reference to the Yaris... I was stating I had one in my 330, and it made a difference. Read.
Old 01-17-2007, 10:16 PM   #7
gr8yaris
gr8yaris's Avatar
Drives: 07 Yaris Hatchback
Less "rotational mass", more horepower goes thru to the wheels. There is also faster clutch engagement during shifting. I replaced the stock 15 lb flywheel in my JDM powered 1.3 L turbo Tercel with 8 lb JUN flywheel and it was a huge improvement in acceleration.
Toyota Yaris............1.5L NA.......2300 lbs....... HP=105+
Toyota JDM Tercel....1.3L Turbo...2100 lbs....... HP=160+
2007 White Liftback 5-speed
Tanabe DF 2" lowering springs, 205/50-15 on 15x6.5 Konig Helium, TRD rear sway bar, 15mm Hub spacer
http://picasaweb.google.com/USAntonio/MyGarage#
gr8yaris is offline   Reply With Quote
Old 01-16-2007, 12:33 PM   #8
St_G
Drives: Black 2007 Yaris Liftback 1.5
I get nervous about mods in the powertrain that aren't TRD; it just seems like it would be too easy for warranty work to be denied.
St_G is offline   Reply With Quote
Old 01-16-2007, 01:16 PM   #9
acrbill
That is very true. If you have warranty work done on the engine or trans and they discover an aftermarket flywheel there is a good chance they will deny coverage.
This is probably not a mod for the bolt on mod crowd.
Old 01-16-2007, 06:14 PM   #10
dngz
dngz's Avatar
you think a $800 CAD Tom's lightweight flywheel will be under warranty?
Old 01-17-2007, 01:32 AM   #11
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
Damn, i aint spending no $800 just for a flywheel, thats crazy.
Yaris TTE JWRC is offline   Reply With Quote
Old 01-16-2007, 06:51 PM   #12
ChinoCharles
Drives: LB
A good way to check would be to call the dealer and see if they'll install it.
Old 01-18-2007, 02:40 AM   #13
graywolf_14
Drives: um not a yaris but hopefully
Or if it looks basicly like a stock one dont say a dang thing.
graywolf_14 is offline   Reply With Quote
Old 01-18-2007, 09:32 AM   #14
Chris07LB
Chris07LB's Avatar
Old 01-18-2007, 01:53 PM   #15
gr8yaris
gr8yaris's Avatar
Statement ^^^ doesn't make sense.
Old 01-18-2007, 01:01 PM   #16
boris13
Drives: 2007 Yaris Liftback, 5-speed
Will a lighter flywheel decrease torque?
boris13 is offline   Reply With Quote
Old 01-18-2007, 01:05 PM   #17
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
No.
Old 01-18-2007, 01:16 PM   #18
CASTREX
CASTREX's Avatar
But on the down side, I've heard that revs will also drop faster... is this right?
