Old 03-08-2009, 09:11 PM   #1
joeharth
Drives: 2007 Hatchback
rim size
Hi i believe I got some kind of sport package on my car. The rims are 15 inches. is this stock on most yaris? Does any one know if there is an option for 14 inch rims? I am not crazy about the handling of my car , I would like to hear from others may be this would improve with 14 inch wheels?.
joeharth is offline   Reply With Quote
Old 03-08-2009, 09:19 PM   #2
06vitzRS
Drives: 06 Yaris HB
You purchased a Yaris not a sports car so you shouldn't expect much in the perfromance and handling department. However, if you go up to 16 or 17 inch rims, add lowering springs and a rear sway bar, your car will "handle" very, very well.
If you go to a 14 inch wheel, you will have even more tire side wall flex than you do now and the handling will get even worse.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 03-08-2009, 09:22 PM   #3
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
I guess for the yaris, the 16's are the best size performance wise, albeit the tyres for 15's are cheaper.
If you are into looks get the 17' (which are more common)
Stock yaris depend.. .Here in australia; we have 3 version of yarii; YR which have 14 steelies, YRS with 15 steelies and YRX with 15 alloys (correct me if I am wrong)
Old 03-08-2009, 09:24 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
The 14" wheel is neither standard nor an option on the US Yaris.
If you want to improve handling, replace the tyres with something stickier and wider, plus install a rear anti-sway bar. You'll be surprised the difference this will make.
Old 03-08-2009, 09:25 PM   #5
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I have 14" Steelies that are 5" wide they are more responsive and fuel effecient then the 15x6.5 Konig Heliums I had.
bdc87 is offline   Reply With Quote
Old 03-08-2009, 09:32 PM   #6
SailDesign
Drives: .
But they have different tires on them, which may well (read "WILL") make the difference. The wheel itself does nothing but support the tire. (For the pourists, Yes, a lighter wheel aids acceleration....)
"Responsive" and "fuel efficient" are interesting words to put together like that.
Old 03-09-2009, 02:09 PM   #7
bdc87
bdc87's Avatar
Yes it might of had something to do with the difference in weight, not sure how much the stock tires weigh? But the steelies are 14lbs and the Heliums 10.8lbs. However a lighter combo should and alteast for me gave me better mileage and the lighter weight made it more responsive. I've also read somewhere that the width is a factor in traction the only thing it seemed to affect was my mileage, also more rotational mass with larger wheels? I went down to 30mpg with the heliums and I'm at 36mpg with the steelies. My plan is to now get some Miata wheels and the lightest tire I can find.
Old 03-09-2009, 08:01 AM   #8
MUSKOKA800
MUSKOKA800's Avatar
Start by adding a rear anti-sway bar then work from there. It's a relatively inexpensive upgrade, simple to install (TRD is anyway) and makes a world of difference.
rim size phenoyz Fuel Economy Forum 7 02-10-2009 02:11 PM
Exhaust Pipe Size (Tamaño del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 03:20 PM
Bulb size (application) question. W.A.S.P Cosmetic Modifications (Exterior/Interior) 4 10-01-2006 02:21 AM
