Old 02-21-2009, 11:09 PM   #1
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
Cannot Remove !#*#@$ factory oil filter!
I've spent the last 2.5 hours trying to remove the stupid factory installed oil filter from my '09 and can't! I've been to three auto parts stores and Wal-Mart with no luck! I cannot find a filter wrench that will fit the stupid thing! I tried a bigger wrench with rubber wrapped around it and it also won't work, nor will my rubber strap wrench.
Help! I need to drive the car > 200 miles tomorrow and I'm afraid that the dents that I put into the can might cause a leak if they're too sharp!! Any advice?
twowheels is offline   Reply With Quote
Old 02-21-2009, 11:12 PM   #2
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
what i found that works well is the filter wrench that looks like a crescent.... my ex just used that on my car last week and it worked well...
$15 at kragen
Old 02-21-2009, 11:18 PM   #3
twowheels
$15 at kragen
I tried a wrench that looked almost exactly like that. It would barely fit between the engine block and the filter at the angle that was necessary to be able to rotate it. It's also the one that dented up my can making me afraid to just refill it and change the filter later.
Old 02-21-2009, 11:17 PM   #4
Use a filter cap. If it's slipping, soap/wash rag the oil filter, apply 2-3 layers of masking tape around the tip, circumnavigating it, and then put the cap on and twist off. That's how I've been doing it.
Old 02-21-2009, 11:30 PM   #5
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
hmm then maybe u should think about having someone else do ur oil? we had no problems.. iv even used a slip wrench on it once and it worked..
Old 02-21-2009, 11:36 PM   #6
Jack up the car too, gives you more space to get under, which gives you more leverage.
Old 02-22-2009, 12:15 AM   #7
twowheels
I've done many oil changes in the past and never had this problem... not sure why I'd expect to have to get somebody else to do it.
I finally got it off by going to buy the biggest pair of slip joint pliers that I could find... that thing was stubborn.
Now the problem is that I can barely read the dipstick since the oil is so clean. I put in the expected amount of oil and it's really hard to see where the oil ends on the stick. I'm accustomed to much dirtier engines!
Old 02-22-2009, 12:18 AM   #8
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
lol well glad u were finally able to get it...
Old 02-22-2009, 01:11 AM   #9
SilverGlow
Drives: 2007 Yaris Hatchback
It's not so hard...jees us! Just puncture it with a philips screw driver and hammer then turn the damned thing to loosen, then hand turn it off....all this in 1 minute....2.5 hours?!? WOW!
SilverGlow is offline   Reply With Quote
Old 03-09-2009, 11:57 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Came in to post this. make sure you apply some oil around the gasket on the new filter so this doesn't happen again
Old 02-22-2009, 01:15 AM   #11
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Jill, or others:
With new cars, they (manufacturers) tend to screw the filters in really tight. When I bought my car, they gave me a voucher for a free change, I applied it for the very first change. Other cars I've had, the filters were on really tight.
Back to the subject. When I had a Tacoma, my first oil change consisted of a worn oil cap and lots of elbow grease plus hot crafts glue.
1. The cap was gone, it would not work again
2. I hot glued the inside of the cap and stuck it onto the oil filter.
3. Worked---FINALLY.
Other options, more messy:
1. Punch a screw driver right into the side of it, right through the filter.
2. Twist off with the screw driver.
Gooogle for more possiblilities...EVERY FORUM has a thread on how to get a stuck filter off.
Edit: This the exact reason why I advise hand tight when you put on the new one back in my "how to" write up--As in don't worry about torque specs.
Old 02-22-2009, 01:25 AM   #12
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
hah good one Dave i was gonna do it myself.. then i couldnt get my oil drain plug off.. good thing i had my tool aka ex boyfriend there.. he did all the work.. but i bought the oil! hey. i bought his too.. gotta give the evo a drink once in a while, evolynn gets thirsty too...
Old 02-22-2009, 01:30 AM   #13
twowheels
I'd considered the screwdriver through the side of the filter, but if that'd failed I'd have been left having to have it towed so that was a very last resort!
Old 02-22-2009, 02:01 AM   #14
rningonfumes
Honestly, it's a tin can, just do it already. You're looking for that extra leverage. Put your hands evenly, with equal pressure and twist.
Old 02-22-2009, 02:38 AM   #15
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
I use this cup wrench the smallest size and a picture from the DIY
Red Horse is offline   Reply With Quote
Old 02-22-2009, 04:49 PM   #16
MUSKOKA800
MUSKOKA800's Avatar
I use this type with a 3/8" ratchet and 8" extension.
Works like a charm.
I do run my car up on ramps to get easier access.
Old 02-22-2009, 03:56 AM   #17
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i had the same issue doing the 1st change on my car as well. they put it on really tight from the factory. now that the first one is done all the others have been a breeze. :)
mikenacarato is offline   Reply With Quote
Old 02-22-2009, 04:59 AM   #18
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
so did i, i think how close the filter is to the block is one of the stupidest idea's ever, i don't have problems getting mine off but it is so dam close, what were they thinking ??
id3379 is offline   Reply With Quote
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 02:00 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
