#1 |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
Nippon Oil Filter
Well, a little bit of story first...
my friend bought this 98 Corolla VE 2 months ago. It was a very sweet deal... 2500$ with only 48000km. The body is not in that great shape.. it's bumped, dinged here and there. Anyways... with just 48k km~ Ok, i suspect if it's real or not... Since we were changing the oil.. i took time to check all the oil level... the air filter and such. It had a denso air filter, brake oil was new, automatic transmission was still red. It also runs like a 48k km car.. It doesn't take any oil either... so i guess it was a good buy ?? alright.... back to topic. The first surprise is that the previous person who did the oil change tighten the freaking drain bolt to hell.. it felt like he did it with an impact gun!! Once taken out, the washer was completely compressed. So finally come the oil filter... From the top of the engine, i thought it was an original oil filter, as i don't know many aftermarket filters that make them in black with white writings.... it had japanese written on it.. so checked it out... NIPPON FILTER?!??! wtf? Is it the same filter as the original Japanese made Denso filter?? This is exactly the same size filter that fits our yaris.... |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
most of the non toyota oem filters are not vehicle specific take fram for example they showed for most model years toyota's to use either a 4967 or a 3593 filter, or group7 filters call for a 4477 or a 4610 or a cartridge depending on the model
meanwhile toyota o.e.m uses practically a specific filter for each car off the line... |
#3 |
actually no... toyota uses only 3 different oil filters across their entire car models lineup.
#4 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Looks like the filters that Napa Auto Parts sell thru their Altrom import line. I used Ultra-8/Nippon before I made the switch to Amsoil's Ea oil filter.
#5 |
#6 |
Yes. Toyota have 3 different OEM filters for their entire line up.... At least, up untill 2005.
#7 |
| Super Amazing Oil Change DIY | id3379 | DIY / Maintenance / Service | 34 | 11-28-2008 01:20 PM |
| What about the oil filter???? | Driver | DIY / Maintenance / Service | 28 | 10-23-2008 11:45 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| don't think the dealer changed oil filter on first change | gonzo452001 | DIY / Maintenance / Service | 0 | 01-13-2007 11:44 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
