Old 03-22-2009, 10:25 PM   #1
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
Front camber bolt & Rubber bushings..
Hey guys.
I wanna get some Front camber bolts,
and rubber bushings, and most probably install them at the same time.
What are the options for yaris Hatchbacks?
How do i know which bushing will work with my yaris?
Thanks in advance.
Harvey
harveyjai is offline   Reply With Quote
Old 03-22-2009, 10:27 PM   #2
supmet
Drives: 2007 4 Door Yaris
Microimage sells the camber bolts, don't know about bushings
http://shop.microimageonline.com/cat...c?categoryId=4
Old 03-22-2009, 10:32 PM   #3
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
wow..looked like an OEM product??
Old 03-23-2009, 06:00 AM   #4
lunjiaow
lunjiaow's Avatar
Drives: Yaris
I got some whiteline camber bolts. Only to correct camber back to stock settings for now..
Also if you get aftermarket bushings wouldn't you get a harsher ride and rattle your whole interior to bits.? Its only what i have heard, never had bushings done before.
lunjiaow is offline   Reply With Quote
Old 03-23-2009, 11:30 AM   #5
MUSKOKA800
MUSKOKA800's Avatar
OEM bushings are rubber .
Are you sure it isn't urethane bushing you're seeking?
Yes, Harm has camber bolts, and much cheaper than the alignment shop hit me up for mine.
Old 03-24-2009, 12:24 PM   #6
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
so i should get bushings?
i thought it helps u conrner better..
Old 03-24-2009, 01:18 PM   #7
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The question is not if you should get bushings?
but where would you get bushings from? As there are no bushing kits available for the Yaris.
Do you feel that your doesn't corner very well? what suspension mods do you have?
If you want your car to corner better you start by:
Springs
Tires
Rear Sway bar
If you have all those and you still feel your car is nor cornering weel enough...
Take a look at Tamago's handling thread. Is a sticky on the suspension forum
Old 03-25-2009, 10:06 AM   #8
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
I got TRD springs ad shocks, Ku36 tires, and Ultraracing rear sway bar.
It does do well, is just that i m thinking whether the bushing will improve even more.
Btw, is it worth it to replace my TRD spring into TANABE DF210?? would that give me lower ride height and stiffer setting?
Old 03-25-2009, 12:08 PM   #9
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
camber bolts shouldn't cost more than $16 for the pair.
search around.
Ingalls from Summit racing for example.
Russelt3hPirate is offline   Reply With Quote
Old 03-26-2009, 05:46 PM   #10
CASTREX
CASTREX's Avatar
No you stay with the TRD's. The Tanabe will drop yor car a little more than the TRD's but they are not stiffer.
The TRD shocks and and springs were designed to work together.
You are on the right track with your set up...
unfortunately there are no bushings for the Yaris yet.
You can look into the front camber bolts. Garm sells those or you can probably got them locally also. It's a cheap mod that will help you to dial a little bit of negative camber.
Other than what you have there is not much more to do... other than go to a full coilover set up...
There are a bunch of braces available but you alrady got the rear sway bar and that is the most important...
I say you go out and drive and enjoy your car... it should drive pretty well by now...
Old 03-26-2009, 06:51 PM   #11
True for bolts that set a specific camber. I've never seen adjustable ones for $16/pair.
Old 03-26-2009, 08:30 PM   #12
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
bs
Its a Chao!!!
Old 03-28-2009, 06:34 PM   #13
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
Originally Posted by CASTREX View Post
No you stay with the TRD's........
i did enjoy my car..thanks for advice buddies!
http://www.youtube.com/watch?v=F3iZuZ6VrOQ
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 11:44 AM
Dont forget the camber bolt. nurburgring Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-23-2007 04:39 AM
