![]() Drives: Yaris 1,3 -01 Linea Luna Join Date: Feb 2010
DRL in Yaris from..?
Hi,
I decided to add an other thread also in here Modifications, maybe you know better. So the question is, where from Yaris have DRL (Daytime Running Light)s? I have Yaris 2001, so is all Yaris made with DRL? |
The electrical wiring diagrams for 2001 show that some had and some did not have DRL. So, it looks like it was on some Yaris that far back. Even with the current model year (2010) some markets have DRL and some do not.
Is it possible to verify is there DRL or not without taking the cover out under the steering wheel? Can saw it for example from lights or their type of working?
Yes. If your Yaris has DRLs, as soon as you start the engine the headlights will turn on. If they do not, then your Yaris does not have the DRL module.
I tried to find DRL module under the steering wheel, but did not found it. There were a few empty sockets and I thought is someone removed the module.
But, when is start the engine, headlights will turn on after one or two seconds, tricky.. Anybody knows where is could find the module and what kind the socket of the module is? |
ups
#9 | |
Anyway, I get the hid-kit working with this kind of relay harness? Right? I thought that this kind of relay kits are made for H1/H7 kits on so on that they get power directly from battery. Is that kind of relay kit really needed to pass the DRL? I don't get how that differs from original H4 kit because there power always come directly from battery..?
In DRL mode, the headlight bulbs are driven at a lower voltage by pulsing the power to them. That is what makes the DRLs flicker. The relay kit gets past that issue by feeding the HID ballasts full battery voltage instead of the output of the DRL module.
#11 | |
And all Yaris has the H4 socket (and usually people get Bixenonkit), so there should not be any problem with DRL because power comes directly from battery. |
The headlight switch switches the ground side. The bulbs have power going to them and then the switch makes or breaks ground to the other side. The DRL relay pulses that ground making it look like the bulbs are being run at 1/2 voltage. The relay kit should make it where the other side of the feed is ground or no connection, not the pulsed ground.
#13 | |
Does that relay kit look right and working which I posted few messages before? |
#14 | ||
#15 | ||
This seems to be my monolog but, I get the fron dash off with CTScott instructions! That was easier than I expected and the DRL was right under the dash. Thanks! I found the DRL module with number: 82810-52020 whic differs from DIY instructions (http://www.yarisworld.com/forums/showthread.php?t=894). In this DIY number was 82810-52040. I think that module I found is DRL because google search: 82810 RELAY ASSY, RUNNING LIGHT 82810‑52020 NCP1*, NLP10, SCP10..JPP..LHD..(LUNA, SOL, TRSTD, TS) 1 http://www.toyodiy.com/parts/p_E_200...html?hl=85916D So, yei! Problem solved (hope so..) |
#16 |
Yes, you definitely need a relay. I am not familiar enough with the wiring for that generation of Yaris to be able to tell if the relay kit in your picture will work.
#17 | |
![]() I was just confused because Bixenon kits come with relay which controls the bulb for low/high beam but the kit need the additional relay kit for fooling the Daytime running light.. The relay harness gets power directly from battery but normal bixenon system do the same. Basically there is no difference by using original h4-bixenon system or relay harness. Both get the switch from car's original h4 socket. So what is the difference? Maybe I am stupid but I don't get it... anybody help Last edited by Falconia; 02-17-2010 at 02:43 PM. |
#18 |
That's correct. Your generation of Yaris had a different part number than the newer generation.
If simply disconnecting the module doesn't do the trick, then snap a picture of the connector. If the EWD that I have matches the wiring for your area, then I believe that you will need to disconnect the yellow wire (between the two greens) and leave the module in place. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 06:46 PM |
