Old 04-22-2009, 11:11 PM   #1
detroiter
detroiter's Avatar
Df210 + Tokico Blues = Rubbing?
I'm thinking that the TRD springs are not going to be a low/stiff enough spring for me, so I might be heading towards the df210's. My question is though, I've been reading about some rubbing with these springs. I'm going to be staying with the stock 15" rims and tires. I'll also be putting on Tokicos with the springs when I do the springs, should I have any rubbing issues at all? Another question is how do you folks with df's deal with speedbumps :)
Old 04-23-2009, 09:32 AM   #2
detroiter
detroiter's Avatar
bump
Old 04-23-2009, 11:49 AM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
The rubbing is because of wrong offset wheels not because of the springs.
If you stay with the stock rims, you will be OK with the DF's and should not experience any rubbing!
Down the road if you want to upgrade rims, just make you get the right offset for you ride height.
Old 04-23-2009, 11:53 AM   #4
+1. The stiffer shocks will lessen any rubbing not increase it, also.
I have all of those parts for sale, FYI
Old 04-23-2009, 03:36 PM   #5
33OH
Drives: '08 Yaris
I run DF210's on stock shocks/struts and I only rub if I cut my wheel all the way one way, and it's VERY minimal. Speedbumps I don't rub, normal driving I don't rub, 4 people in my car, still no rubbing.
Old 04-23-2009, 03:38 PM   #6
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
doooo it!
Old 04-23-2009, 03:45 PM   #7
mrbond
mrbond's Avatar
What's the offset of your wheels?
- A Toyota Yaris
- A whut Yaris?
Old 04-23-2009, 04:04 PM   #8
33OH
Drives: '08 Yaris
17x7 +42
Old 04-23-2009, 04:31 PM   #9
Pitt Yaris
Drives: Flint Mica Sedan
Edit: answered. Thanks
Old 04-23-2009, 04:32 PM   #10
33OH
Drives: '08 Yaris
All listed here: http://www.yarisworld.com/forums/showthread.php?t=5021
Old 04-23-2009, 04:46 PM   #11
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
rubless so far as i gathered for 16's set up is 195/50/16 with +40 and up offset
Old 04-23-2009, 08:45 PM   #12
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
that's impressive...i rubbed quite often with the Tein S-Tech Low's.
Wanted: Forced Induction
Old 04-24-2009, 01:08 AM   #13
detroiter
detroiter's Avatar
Thanks for all the answers guys!
You stated that you don't rub going over speedbumps or anything like that, but your rims are bigger then the 15" stock ones. Would the rim size make a difference in ground clearance at all and with rubbing issues such as if i had a car full of folks?
The DF's and Tokicos are sounding like a mighty tasty combination, just want to get my bases covered
Old 04-24-2009, 11:03 AM   #14
marcus
toyota
marcus's Avatar
its really not the size of the rim but ofcourse theres still a limit..its the width of the rims and tires that makes it rub.
Old 04-24-2009, 12:02 PM   #15
detroiter
detroiter's Avatar
just so i get it straight, i shouldnt experience any rubbing with the df's and tokicos...even with 4 people in the car? also, does anyone have a ground level picture of their df' lowered yaris? I cant find any good pictures that are ground level so i can actually see the ground clearance!
Old 04-24-2009, 12:06 PM   #16
33OH
Drives: '08 Yaris
I don't experience rubbing with DF's except when cutting the wheel ALL the way over.
And here:
Old 04-24-2009, 12:13 PM   #17
detroiter
detroiter's Avatar
thanks for the picture, definately gives me a really good idea! I see your rims are 17", would it make a difference in height that mine is the stock rim and tire 15"s?
Old 04-24-2009, 12:17 PM   #18
33OH
Drives: '08 Yaris
It wouldn't make too much difference, the overall size is still around the same. I've ran DF210's on the stock rims, on aftermarket 15's, and on these 17's with no problems.
Tokico HP (blues) Shock/Strut driving impressions. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 09-09-2010 12:03 AM
NF210 and DF210 lowering springs? jaserhunter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 02-15-2009 08:36 PM
Tokico HP Blues Special Intro Offer kargoboy YarisUniverse 6 01-24-2009 03:51 PM
Tokico Blues + NF210s Installed bdc87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-26-2008 09:39 PM
Tokico Information nemesisz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-25-2007 08:21 AM
